Old 02-17-2014, 01:10 PM   #1
mezcar
Drives: Yaris 2012 Auto
12V supply
Hi folks,
I have a 2012 Yaris (UK spec)
I need 2 12v 1Amp switched supplies for 2 dash cams - one up front, the other in the rear. Please suggest where I can tap the power from? I have a USB in the glove box which currently the ipod is connected to. Thanks
mezcar is offline   Reply With Quote
Old 02-17-2014, 02:08 PM   #2
Do you have a normal key or the smart entry system?
Old 02-17-2014, 04:33 PM   #3
mezcar
Norma key. it's a TR spec with touch and go. I was considering tapping the wire leading to the USB connector for the front. I don't mind rnning some power cabling from the front to the back, but if there was a ready 12V switched supply in the boot (trunk) area, it'd save on wiring.
Also, just out of interest, what is the maximum current available at the USB? The actual dash cams need 5V at 1amp, if I can use a 3 way USB splitter that would save on splicing power cables - 2xUSB for the dash cams and 1Xfor the iPod
Old 02-17-2014, 05:05 PM   #4
I doubt that the USB port can source much more than 1A.
On the front end your best source for 12 Volt switched power is the pink wire on the ignition switch connector. That circuit has at least 5A of available power feed.
At the boot, there unfortunately isn't an ignition switched power source.
Old 02-17-2014, 07:22 PM   #5
mezcar
could i tap the power from the rear of the cigarette lighter? connect 2x female sockets from there?
thanks for your quick response
Old 02-17-2014, 07:23 PM   #6
mezcar
how would i access the pink wire if that is my only option?
Old 02-17-2014, 08:32 PM   #7
The lighter power feed would be fine as well.
For the ignition switch you have to remove the lower steering column cover. There are two screws that you expose by turning the steering wheel in one direction and then the other and a third down by the tilt lever.
Old 02-18-2014, 08:30 AM   #8
mezcar
Really appreciate your help. Thank you so much. What is the best way to access the lighter power feed?
Old 02-18-2014, 10:52 AM   #9
You should be able to get to it by removing the radio. See the thread below for a good DIY on getting the radio out:
http://www.yarisworld.com/forums/showthread.php?t=37300
Car battery 12V 75AH Josepe-sv DIY / Maintenance / Service 11 01-14-2014 03:20 PM
12v power for rearview camera + monitor azeeroth DIY / Maintenance / Service 14 11-14-2012 11:53 PM
12v port modification for extra ports, USB's, etc. tire General Yaris / Vitz Discussion 12 06-13-2011 09:45 PM
Good place to find constant & switched 12V behind dash? atebit In Car Entertainment + Electronics (audio / video / alarm) 16 03-03-2009 11:40 AM
DIY: Discreet Mounting of 12V adaptor for the Gtech & V1 H8SGAS DIY / Maintenance / Service 7 09-26-2006 03:50 AM
