#1 |
![]() Drives: Yaris Verso Join Date: Aug 2013
Vibration or buzzing brake while breaking
Vibration or Buzzing under brake while breaking on 2004 yaris
![]() ![]() When i bought that car around 6-7 months ago, the pads and brake rotors were almost finished. And when i braked the steering wheel was shaking a lot together with the brake. Than i have changed the pads and rotors. By now everything had been perfect, didn't have any buzzing. Lately the vibrations has started while breaking. While driving in high speeds, if i brake than i feel the vibrations. Today i was in a local repairer. He checked all the break systems and he said everything looks as it should be. He didn't have any clue. But we are pretty sure the problem is about breaking system. And as i just mentioned i had just the same problem before. But after changing the pads and rotors it was fixed. So what do you guys think ? Should i go to see a toyota guy or is it possible to DIY ? Thanks |
It may simply be that your new rotors are a bit warped already. If the new pads were not properly "bedded-in" then it is very easy under heavy braking to warp them. Here is an article on bed-in:
http://www.tirerack.com/brakes/tech/....jsp?techid=85
#3 |
Here's another interesting read that says that rotors really don't warp, but rather get uneven deposits from the pads:
http://www.stoptech.com/technical-su...nd-other-myths
#4 |
![]() ![]() ![]() ![]() Join Date: Feb 2010
That is a good write up with useful information....thanks for posting.
#5 |
Very useful and interesting information. Thank you. I will be checking and searching more.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 08:24 AM |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed | RedVitz | Photo-Video-Media Gallery | 18 | 10-09-2010 03:36 PM |
