Old 02-27-2014, 12:19 AM   #1
FlushYaris
Drives: 07 yaris 3dr
Sway bar removal
I don't know if this is a stupid question, but could I technically not run my sway bar and run stiff coilovers up front?
FlushYaris is offline   Reply With Quote
Old 02-27-2014, 01:14 AM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Yes, but you'd need some pretty crazy spring rates(1000lb/in) to compensate for the lack of dynamic roll stiffness.
Old 02-27-2014, 09:57 PM   #3
hairdresserscar
Drives: 07' Yaris sedan
Im not running a sway bar and im lifted... my spring rates are 1000000 zillion I believe. It still conets with little body roll. My wheelbase is also 5.5 inches wider due to wheels.a few guys run autocross without one to keep both wheels planted to keep power down. Al you need is a 17mm socket, a 6mm allen, and ten minutes of your time to take the links off and try it out
hairdresserscar is offline   Reply With Quote
Old 02-28-2014, 12:34 PM   #4
Just undo the end links if you want to disable your sway bar. No need to remove it.
Old 02-28-2014, 02:14 PM   #5
FlushYaris
Yeah thats what I wanted to do to runs a certain type of coilovers. I used to have a mk4 gti 2000-2005s vws. lol We all would cut our sway bars for more clearance for out axles to go lower.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
