Old 03-12-2014, 06:25 PM   #1
dip1
Drives: 2012 Yaris SE
Rusting away..
Have a 2012 White SE. The hatchback is rusting all along the chrome strip above the license plate. Is anyone else having an issue? Its obviously holding water hence the rust.
Thanks
dip1 is offline   Reply With Quote
Old 03-12-2014, 08:27 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
would be under warranty go get it looked at the dealer there body shop will fix it...i have see few Toyota's with same problem mainly Venza and some Corolla....all covered under rust warranty protection ....and yes white looks like main color on all..odd maybe bad paint or something.
Old 03-12-2014, 10:10 PM   #3
matti
Drives: 2017 Yaris L (5sp manual)
I'll have to verify tomorrow, but I'm pretty sure I've got a few rust spots in the same area on my 2012.
matti is offline   Reply With Quote
Old 03-13-2014, 06:29 AM   #4
YodaBird
Drives: Gray
Thanks
Around the license plate, can you take a picture ? I have to check mine, maybe I overlooked that spot, considering the winter has been so cold, with only the odd warm days.
YodaBird is offline   Reply With Quote
Old 03-13-2014, 09:12 AM   #5
matti
Sorry, I was mistaken. I looked this morning and I couldn't find any rust spots on the chrome. I did find a few small rust spots on the sheet metal to either side of the license plate, however.
Old 03-13-2014, 02:30 PM   #6
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Are these little tiny flecks of rust in the paint?
If so, this happens on all cars, but you can actually see it on white cars. A claybar will remove it. I've owned four white cars, and they all get this. It's often referred to as environmental fallout.
However, if it's not this, I got nothin'. :D
Old 03-13-2014, 03:20 PM   #7
matti
Thank you. I'm not sure: I'll have to look a bit closer after work. Is this just "junk" from the road that embeds itself in the paint?
Old 03-13-2014, 05:15 PM   #8
2009D4d
Drives: 2014 Yaris Icon + 1.4D4D
There is a TSB in Europe regarding this issue with a specific repair procedure to follow to ensure the rust once repaired does not return.
The fault is a chemical reaction between the chrome coating on the trim and the fixing holes on the tailgate, the modification involves repairing the tailgate and fitting a modified trim along with insulators between the two. The UK bulletin ref is BO-0086T-1213
2009D4d is offline   Reply With Quote
Old 03-14-2014, 11:35 AM   #9
Thirty-Nine
Yes. Unless this is something more than just environmental fallout. Could you post a pic?
Old 03-14-2014, 11:38 AM   #10
Hershey
The 1st generation Matrix had a sweet spot for rust at the rear door handle on the drivers side .
Old 03-14-2014, 11:51 AM   #11
Mine is a 07 sedan.. and this is what is rusting around the chrome trim. I took out the trim for these pictures.
Old 03-14-2014, 05:53 PM   #12
Thirty-Nine
Wow. My 2005 xB (in 2006) was rusting at a door weld on the driver's side. A number of other owners had the same issue.
Does Quebec use salt on its roads?
Old 03-14-2014, 09:00 PM   #13
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
Thanks
i also have a 2012 se in the blizzard white
i had 2 rust spots in the left side in the middle of the paint, has been repaired under warranty.
i have also developed another right under behind my toyota emblem....
Scubaru Steve is offline   Reply With Quote
Old 03-14-2014, 10:21 PM   #14
jingles
Drives: 1991 Buick Century Custom
White Yarii develop rust easily, blazing blue ones will have their clearcoat start to peel... are there any other problem colors I should know about before I buy one?
jingles is offline   Reply With Quote
Old 03-14-2014, 10:30 PM   #15
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
2012 as well, just showing signs of rust above the license plate
mr9865 is offline   Reply With Quote
Old 03-15-2014, 12:13 AM   #16
YodaBird
Drives: Gray
Can you take a picture ?
Old 03-15-2014, 11:03 AM   #17
Hershey
Geesh , that's a big hole . Any water getting into your trunk ?
Old 03-15-2014, 11:54 PM   #18
Yep, we use salt here. So far, no weld is rusting on my 07. And garage parking it did not help (heat and salt makes a big mess)
I removed the chrome trim to clean the area and protect it a little bit from rusting more. It's not bothering me much since my car is not the cleanest anyways..
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
Yaris design oversight... abattle General Yaris / Vitz Discussion 54 09-24-2010 04:52 PM
