Old 03-22-2014, 09:28 PM   #1
Hershey
Drain and fill : Best to change ATF when cold ?
Would just drive up on ramps in the driveway . Read in manual it takes 2.6 qts. to refill ( 2 qts. 19.2 ounces ) . Last , would I need a new crush washer ? This is the 1st change at about 74,000 miles . Thanks
Old 03-22-2014, 09:43 PM   #2
Although it is no where near as viscous as oil, I find that it flows out better when hot.
I have changed the fluid in three of them without changing the gasket, so I would say that it is fine for at least one change.
Old 03-26-2014, 04:23 PM   #3
barefoot_bajan
barefoot_bajan's Avatar
Drives: 02 vitz rs
hot ATF!!!! ctscott you're a sucker for punishment?
so many pedestrians..... so little time
barefoot_bajan is offline   Reply With Quote
Old 03-26-2014, 05:54 PM   #4
Maybe that's why I have no skin on my right hand?
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
ATF Drain and Fill DMZ DIY / Maintenance / Service 7 05-30-2013 11:01 PM
Auto trans. drain and fill? FochMan DIY / Maintenance / Service 5 01-07-2010 11:41 PM
