Old 03-24-2014, 10:08 PM   #1
Hershey
Alignment needed when both front struts are replaced?
They're also replacing the drivers side rear shock and would that make for an alignment? I also think they are putting in a new front sway bar and the bushings for the new struts. The Tech looked at the control arm bushings and thinks they are fine so this is why all these things are being done. Hope they are right and the creaking stops. Thanks
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
Front Cat Replaced under TSB EG035-06? TheSilkySmooth DIY / Maintenance / Service 20 05-31-2009 08:42 PM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 07:46 PM
