Old 04-14-2014, 01:26 PM   #1
Naka87
Naka87's Avatar
Drives: Toyota Yaris
Servicing..
Okay, I'm a little puzzled. I've called to make an appointment for my Yaris this weekend. I was under the assumption that a tune up included belts and wiring. But now I'm being told something completely different. Is this normal to occur?
Naka87 is offline   Reply With Quote
Old 04-14-2014, 02:11 PM   #2
the yaris does not have a distributor.. so no wires to change.
drive belt (alternator & AC are 1 belt) are not due, if it doesn't show signs of cracking (rubber dry rot)
spark plugs on the 1nz are usually iridium plugs and can last like 80k miles.
Old 04-14-2014, 03:35 PM   #3
Naka87
Naka87's Avatar
Thanks. Because I became sfrustrated quickly. Felt like I was getting the run around. I'm at 102,000 miles now. And I was told that my shock absorber is missing from my glove box.
Old 04-14-2014, 04:09 PM   #4
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
a shock absorber missing from your glove box?
DebbyM46227 is offline   Reply With Quote
Old 04-14-2014, 04:19 PM   #5
nookandcrannycar
^^^^^ This. Did you actually make the call on April 1st ? (just kidding)
Old 04-14-2014, 04:30 PM   #6
LOL the glove box have a strut kinda thing that makes it open up slowly.. instead of slamming down.
This tends to be lost, or forgotten to be put back when changing the air filter. It doesn't really matter if you don't mind how your glove box don't open like an Audi.
Old 04-14-2014, 04:31 PM   #7
Naka87
Naka87's Avatar
😱 ... So now they may charge me for it!!! Smh.
Old 04-14-2014, 04:32 PM   #8
We don't go in for a "tune up" like we used to back in the 80's. If you've kept up with the maintenance schedule... There is nothing much to get checked.
Old 04-14-2014, 04:34 PM   #9
Naka87
Naka87's Avatar
Oh. So I'm thinking too far back in time. I feel so embarrassed. That's right, I did buy a compact car. Smh. 😅
Old 04-14-2014, 05:02 PM   #10
nookandcrannycar
I wasn't thinking outside the box . I wonder what Toyota's official name is for that part ?....and for that matter the 'shock absorbers' for the hatch ?
Old 04-14-2014, 08:17 PM   #11
The Limo 2
According to the maintenance schedule what is needed at 100,000 miles is
1. Change coolant
2. Change engine oil and filter
3. Reset oil replacement reminder
4. Rotate tires
5. Visually inspect brake linings/drums and brake pads/discs
Roy
The Limo 2 is offline   Reply With Quote
Old 04-14-2014, 08:31 PM   #12
sex
sex's Avatar
Drives: 09 5DR
The shock is called a stopper http://www.yarisworld.com/forums/showthread.php?t=5158
Old 04-14-2014, 09:33 PM   #13
Naka87
Naka87's Avatar
Oh okay. Thanks. I called Toyota about it and I was told that it's covered under my warranty. So hopefully, it will get fixed or replaced under that.
Old 04-14-2014, 10:57 PM   #14
Kal-El
Kal-El's Avatar
Yes, there's no such thing as a "tune up" anymore, on any car.
Only things to consider is changing the serpentine belt if you haven't yet. A coolant flush. As for the spark plugs, I changed mine somewhere around $120K and they came out with little wear. Up to you how preventative you want to be.
I do minimal maintenance because really that's all the Yaris needs. 163,000 miles and I've only done the above 3 items + tires and one battery change. Oil changes every 5K. Only one repair being a rear wheel bearing.
Everything else is original, even brakes and struts.
Old 04-16-2014, 03:50 AM   #15
Naka87
Naka87's Avatar
Wow..Thanks a lot everyone..You folks have been a lifesaver big time..
Servicing and knocking noise ? mpepper UK 0 05-19-2011 07:04 AM
Window crank on the floor after toyota servicing IMAMEX DIY / Maintenance / Service 5 05-08-2011 02:02 PM
car shaking after servicing Canadian Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 11-25-2008 05:40 PM
10000 km servicing firez3r0 Australia 27 09-29-2007 09:30 AM
Cost of first servicing Island Boy DIY / Maintenance / Service 14 05-20-2006 07:21 PM
