Old 04-25-2014, 06:29 AM   #1
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Straight Pipe thickness advice?
Hey guys
I'm going for a full stainless steel straight pipe on 13th of may,
But I need some good advice on what thickness I need?
Its a 1KR-FE Engine... 3 cylindre 1.0 litre.
I think the original pipe is about 3 cm in diameter?
Should I have the new straight pipe with a 5cm (50mm) diameter?
Thanks
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 04-25-2014, 11:06 AM   #2
Silver Streak
Silver Streak's Avatar
Drives: 2010 Yaris sedan silver
G-ammo, Others can correct me if I'm wrong, but on an engine of that size I wouldn't go as big as 5cm. Keep in mind just going with that straight pipe is going to flow more that your stock system anyway, but going too large may actually hurt performance due to a lack of back pressure.
k&N Pannel air filter
Trd Exhaust
Trd Rear Sway Bar
Silver Streak is offline   Reply With Quote
Old 04-25-2014, 11:34 AM   #3
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
yea man 3cm is barely larger than 1 inch, i doubt its that tiny maybe 1.5" at the smallest and I still doubt that.
I went with 2.25" all the way from header back but I have the 1nz engine
Old 04-26-2014, 04:18 AM   #4
G-Ammo
G-Ammo's Avatar
So how big should I go? maybe 3,5cm then? or 4?
Speedbumps suck...!
Old 04-26-2014, 09:05 AM   #5
1.5
Form>Function
1.5's Avatar
i think 4 is still tiny that is only approx 1.6" how about 4.5-5?
Old 04-26-2014, 05:49 PM   #6
G-Ammo
G-Ammo's Avatar
well that's what i've asked... 50mm (5cm) thickness... but I only have a 1.0 litre engine... isnt that too big ? original pipe is about 3 cm i think... maybe 4...
Speedbumps suck...!
Old 04-26-2014, 06:27 PM   #7
Rigaud
Drives: 2009 Yaris
1.0L engine = 1.75" or 4cm max is fine. Their isn't enough air volume to require bigger and even at that size if it's all straight pipe without a catback you'll lose a lot of power.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 04-26-2014, 06:31 PM   #8
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
http://www.exhaustvideos.com/faq/exh...m-power-curve/
Check this out. According to these folks you should stick with stock diameter if you are making no other upgrades.
sent from my m-o-b-i-l-e
Old 04-26-2014, 06:44 PM   #9
Rigaud
Drives: 2009 Yaris
Exactly, you gain more from staying with stock size but going with mandrel bent pipes. Same with cold air intakes that usually only gives a faster throttle response but no real h.p. gains on small engines. Read alot of research and studies on it.
Old 04-27-2014, 02:50 PM   #10
G-Ammo
G-Ammo's Avatar
Thanks guys! So when reading that table of the diameters... its better to stic with 3 cm / 3,5 cm in diameter or else i will lose alot of power.
I just emailed the performance shop about this.. I hope to get a positive answer this week.
Speedbumps suck...!
Old 04-27-2014, 04:45 PM   #11
Rigaud
Drives: 2009 Yaris
Old 04-27-2014, 06:40 PM   #12
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
Me coming from "old school" modding.... The whole idea I was taught with "straight pipe" is to get exactly that... As much straight, unbent, pipe as you can replace from the cat back. Also... You want to have a section ABOUT the size of a muffler where the origin pipe sets inside (via weld) a slightly larger pipe. I've done this on several cars. Sounds angry. I've always loved this "glass pack without glass" sound!
trunkout is offline   Reply With Quote
Old 04-29-2014, 11:56 AM   #13
G-Ammo
G-Ammo's Avatar
Ok so they replied:
they say 40mm should be the best because I still have enough airflow and stainless steel holds warmth better than the original. Plus i have enough back pressure cause of my cat and my header turbo on the nitto axle back exhaust.
I also asked them if they can put the exhaust pipes deeper into the chassis, because im so low to the ground, haha. Hope they don't mind doing that... :P
Speedbumps suck...!
Old 04-29-2014, 12:14 PM   #14
1.5
Form>Function
1.5's Avatar
how would the method of molding the metal effect performance?
Old 04-29-2014, 12:56 PM   #15
Rigaud
Drives: 2009 Yaris
look up mandrel bending. Pipes stay perfectly round in bends where as stock pipes are flattened and or rippled in the bends. Stock pipes have air flow restrictions due to that.
Straight pipe? FlushYaris Performance Modifications 29 04-28-2014 12:19 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
Benefits of Removing Cat and Running Straight Pipe? Nexus1155 Performance Modifications 68 03-29-2012 01:00 AM
2.5' First Cat Straight Pipe with Greddy Ti-C gwasabi Performance Modifications 15 03-01-2009 10:50 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
