Old 05-29-2014, 04:11 AM   #1
GSKNAIR
GSKNAIR
Drives: TOYOTA YARIS
2008 YARIS AUTOMATIC 1.3 LITRE ENGINE
HII,
i AM FACING PROBLEMS WITH MY CAR , THE AC COMPRESSOR IS CHANGED THRICE BUT AFTER ONE MOTH TIME THE AC COMPRESSOR IS GETTING DEAD . INITIALLY ITS GETTING OFF AND SLOWLY AFTER CUT OFF GETTING ON BUT LATER ON IT BECOMES COMPLETELY OFF AND NOT GETTING ON AUTOMATICALLY AND THEN COMPLETELY OFF .
i AM SO CONFUSED , PLS ADVICE
GSKNAIR is offline   Reply With Quote
Old 05-29-2014, 09:23 AM   #2
Has the refrigerant pressure been checked, or have the compressors just been replaced? If the pressure is too high (overcharged) or too low (a leak somewhere) the compressor will shut off to prevent damage. There is also a pressure sensor on the aluminum tubing near the sight glass. If that sensor is bad (pressure measures correctly on both the high pressure side and low pressure side of the system), then that sensor may be bad.
Is your Yaris engine quiet? andy64 General Yaris / Vitz Discussion 8 08-29-2013 07:07 PM
2008 UK 5 door Yaris 1.3 TR Steering wheel/pad. JOHNVW DIY / Maintenance / Service 8 07-21-2013 04:37 PM
