Old 07-23-2014, 05:38 AM   #1
nacer
Drives: yaris
Horn Not Working
hi
i have 2012 Yaris hybrid (Hatchback)
So...the horn doesn't work! Is there a relay or fuse that i should check - Diagrams Etc?
or where locate the horn relay
fuse is ok
horn is ok
- Zee
nacer is offline   Reply With Quote
Old 07-23-2014, 06:35 AM   #2
The horn fuse and relay are located in the fuse box that is next to the battery. The relay is within the block that the fuse is mounted to, so replacing it requires replacing the entire "integration relay" block. Check the fuse first and if that is OK, have someone press the horn while you put your ear against the integration relay to see if you hear the relay contacts click when the switch is pressed.
Old 07-25-2014, 02:48 AM   #3
nacer
Drives: yaris
this image(relay and fuse box)
where locate the horn relay ???
Thank you, CTScott!
Old 07-25-2014, 06:33 AM   #4
It is within that white block with the fuses in it. Look at the cover for the fuse box to see which fuse is the horn one and the relay is directly beneath the fuse within that block.
Old 07-25-2014, 07:03 AM   #5
nacer
Drives: yaris
How to Remove white block ???
Thank you, CTScott!
Old 07-25-2014, 08:57 AM   #6
There is a tab on either end that you release
horn not working
Horn Not Working Zee518 DIY / Maintenance / Service 8 07-17-2016 08:05 PM
Help! Turn Signals and Horn Stopped working kashanf DIY / Maintenance / Service 3 05-28-2014 05:20 PM
Car horn not working on the right-hand side Toyota3000 DIY / Maintenance / Service 1 12-26-2013 01:57 PM
horn stopped working sickpuppy1 DIY / Maintenance / Service 11 07-17-2013 12:32 AM
Help! Horn just stopped working. steveh74 General Yaris / Vitz Discussion 14 09-17-2009 10:23 AM
