Old 07-30-2014, 11:27 PM   #1
shot
Drives: 2007 toyota yaris
Post Vibration in front end
The vibration is worse at higher speed, come and goes. any ideas
shot is offline   Reply With Quote
Old 07-31-2014, 12:50 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Wheel balance is first on my mind
Old 07-31-2014, 01:02 AM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Normally, it's better at higher speeds but everyone is different. Check the penis.
Old 07-31-2014, 01:36 AM   #4
nookandcrannycar
Old 07-31-2014, 01:53 AM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Instructions not clear enough. Penis is now stuck. Please advise.
Check out my Build thread:
Old 07-31-2014, 02:20 AM   #6
nookandcrannycar
Old 07-31-2014, 11:15 PM   #7
shot
it does not feel like tire balance more off acme and go vibration
Old 07-31-2014, 11:48 PM   #8
nookandcrannycar
Roughly how many miles are on the odometer ?
Old 08-01-2014, 01:00 AM   #9
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
hmmm...
Old 08-01-2014, 01:27 AM   #10
ezhacker1
ezhacker1's Avatar
Does the vibration have a corresponding sound that gets louder when going faster? Could be a bad wheel bearing
Old 08-01-2014, 09:52 AM   #11
shot
133000
Old 08-01-2014, 12:02 PM   #12
alanwagen
belt slipping
Tires do get out of round. Many a time, new tires fix the problem.
Anytime you fix a flat, the radial belt will move and the tire will get out of round.
Old 08-01-2014, 04:38 PM   #13
nookandcrannycar
133000
That might be enough miles (if you drove really hard on really bad roads) that some of the bushings in the front suspension (tie rod end bushing ?...etc.) might be worn, or the steering rack might be fried (mine was fried in my Suzuki Swift by 151k miles...with only parts of the last 20k miles on hard, horrendous roads). Don't know if those items would cause the particular vibration you are feeling.
Old 08-01-2014, 11:41 PM   #14
shot
thanks for the info. I worry that it might be a bearing in trans. where the cv shaft goes in. but I don't how you can tell
Old 08-01-2014, 11:54 PM   #15
nookandcrannycar
When I've had CV joints go bad in different cars, the noise was always a clicking that might develop into a thumping if it progressed before repairing. Don't remember getting a symptom that I would classify as a vibration. However the sound always came from closer to the left or right wheel than what you seem to be describing.
Old 08-01-2014, 11:57 PM   #16
nookandcrannycar
New tires sometimes correct multiple ills.
Old 08-02-2014, 12:23 AM   #17
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
wheel balance first ...then move on to other stuff if still there
Old 08-05-2014, 04:41 PM   #18
esse10
Drives: 2009 yaris 2 door
vibrations
I had a similar issue a while back and just rotating and balancing the tires fix that front end vibrations.
Help! Can't figure out this front end clunk over bumps. suprasb DIY / Maintenance / Service 9 07-08-2013 12:58 AM
MI SSK In-Cabin DIY (Golddeenoh) BEEF DIY / Maintenance / Service 5 03-26-2013 01:19 PM
Question about the new 2010 yaris front end differences? YarisSedan Cosmetic Modifications (Exterior/Interior) 4 06-12-2010 02:27 PM
2008 Yaris 5000 km noise in front end!! help! Jen General Yaris / Vitz Discussion 3 08-26-2009 08:29 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
