Old 08-02-2014, 07:07 PM   #1
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
guide pins on brake housing
Does anyone know if the slider pin with the rubber ring goes on top or on bottom of the brake housing? Thank you.
33.7 mpg in PA
bad is offline   Reply With Quote
Old 08-02-2014, 07:17 PM   #2
bad
Winterizing
bad's Avatar
sorry to post so soon. I thinkI found my answer in the diagram on this thread.
http://www.yarisworld.com/forums/sho...ight=guide+pin
33.7 mpg in PA
Old 08-02-2014, 07:31 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Good to know you found an answer.
Caliper guide pins corroded with rust PICS auxmike DIY / Maintenance / Service 15 07-11-2015 08:54 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
