Old 08-02-2014, 06:20 PM   #1
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Tire size help?
Hey everyone, I was hoping you guys could answer a question for me:
I have xxr 522 R16x7 +25offset
Like this: http://www.ebay.com/itm/XXR-522-16-1...item43cc17d445
I want tires that wont stick out too much. I have tried on 205/50/16 but it sticks out a little too much, is it because of the offset?
Could someone tell me a good tire size to run that it wont poke too much. Thanks so much
-Alex
nobodywise is offline   Reply With Quote
Old 08-03-2014, 12:08 PM   #2
Your offset is not correct to not stick out.
Old 08-03-2014, 12:17 PM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
Even with 195's, you're going to poke up front.
Old 08-03-2014, 01:19 PM   #4
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
I guess I'm going to have to accept the power of the poke lol but what's the best tire size to run that will reduce the poking look a bit.
Also what offset would you recommend for not poking on a sedan with 16s
Old 08-03-2014, 01:31 PM   #5
kimona
kimona's Avatar
Run 195/50/16's with your current wheels... and without any suspension tweaks, you'll probably poke up front 10-12mms.
If you want to run 205/50/16's, ET42 will be flush up front.
Old 08-03-2014, 03:38 PM   #6
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Thanks illusion
I literally just put it on 'lotek' lowering springs (which is supposed to be a 2 inch drop) until I can afford coil overs
I was thinking 195/45/16 but it's not a big difference from the 50s
Maybe some camber is in order? Haha
Old 08-04-2014, 08:58 AM   #7
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Alright kimona, I've decided to ditch those rims now
I would like my rims to be a little bit behind the fender so when I get lowering springs I can tuck tires.
If I run 16s what offset do I need to make that happen?
I'm thinking Weds Sport TC-105N Wheels 16x7 et43
Or I might go with 17 what are the safe offsets to sit right behind the fender to go lower?
Thanks again
Old 08-04-2014, 09:27 AM   #8
You won't get 17" if you want hellaflush..
Old 08-04-2014, 03:15 PM   #9
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
This is how it looks now with a 2 inch drop with the 14" stock steelies
And with the 205/50/16
It's pretty close but I wanted it under the fender. Gonna have to sell these rims and get some with more offset
Old 08-04-2014, 03:43 PM   #10
The thing is with 17". It's going to be 17x7 and you are going to rub inside if you have too little offset.
Anyways, if you want inside the fenders, you are going to have to drop more anyways.
Old 08-04-2014, 03:51 PM   #11
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
Well it's 16x7 so it's the same width as the 17s. I'm gonna go with a 40 and up offset regardless. How do you guys know when it will be under the fender or too far out?
NITROGEN GAS TIRE FILL: WORTH IT? EjDaPogi Middle East 15 03-20-2011 02:06 AM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
Tire Size Sabretooth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 04-09-2007 12:28 PM
