#1 |
How to turn a Yaris into a Tacoma
I recently sold my Tacoma, as the only thing I really used it for was my weekly trip to the recycling center. I don't like the idea of carrying trash or recyclables inside my car, so I decided to turn my Yaris into a proper Tacoma replacement.
I found a hitch rack that would perfectly fit my two cans and then added a Curt hitch to my Yaris to mount it. I purchased the 11050 Curt hitch and the 18145 cargo carrier from thehitchstore.com. I was very impressed with how simple the Curt hitch was to install and how hidden it is. Installation just required releasing the two bottom tabs from the bumper, slipping the hitch up under the hitch cover, and mounting it to the two tie down points with three bolts on each side. Everything was easily accessible and although I had the car on my lift, it could easily have been done on the driveway. Yaris - Carrier 1.jpg Yaris - Carrier 2.jpg Yaris - Carrier 3.jpg
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Ha! Nice.
Another addition from the skunk works in CT. Ummmmmm - "Trashy?" |
#3 |
![]() ![]() ![]() Drives: 2003 Mach 1 Join Date: Oct 2008
NICE!
#4 |
Always wanted one of those!
Not to cause trouble but.... 1) How much weight is safe to haul? The car is FWD and youve got all that weight on the opposit end of the car. 2) Wouldnt that thing interfere with accessing the hatch? How easy to R and R? Thanks!
Synthetic Oil: Its All In Your Head |
#5 | |
1. The rack is rated for 500 lbs. My cans fully loaded would not likely ever exceed 150lbs combined. If I (~160 lbs) jump up and down on the rack (besides looking quite silly) I find that the rear squats and the front does not seem to be effected. 2. It does interfere with the hatch when the cans are on it. With objects up to 17" tall on the rack the hatch will open completely. By R and R I think you mean put it and take it off. If that is the case, I just slide it into the receiver and slip the receiver pin in (literally seconds on and off). Because the receiver is under the bumper I have to reach through the rack to do so. If the rack had a solid or mesh floor, I would have to reach around from the side of the rack to deal with the receiver pin. It does block visibility of my rear license plate. Thus far (four runs with it) I have not been stopped and I have passed by police cars on the way. The tail lights are still fully visible as the rack is just a tad narrower than the space between them.
#6 | |
So far mine has been used to haul; - luggage - gas cans - pool chlorine - a tree
#7 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2('14+'07)MT 3d ,wHandCrWndws! Join Date: May 2009
2-3 questions: Which size BRUTE cans are you using? (if 50 gallon, then the next question is moot) If your BRUTE cans are the 44 gallon ones or smaller, do you know the largest size can that will fit on that basket? Which strap w/hooks are you using? |
#8 | |
For the strap, I added two eye bolts in place of two of the screws on the carrier, to make it easier to hook on. I started off with one of the ratcheting straps (that I trimmed the excess off to make it perfect for the two cans). I found slipping the end into the ratchet a hassle, so I instead switched to a motor cycle strap. It was about 18" too short though, so I sacrificed a second one and sewed 18" of it into the other one to make it fit perfectly.
#9 | |
I have a friend who lives in one of the colder (during the winter) East Bay (SF Bay Area) suburbs. IIRC, his house is between 3000-3500sf (2 story). He has a pellet stove insert in the fireplace in his living room, and has sworn by it for quite a few years. He's had me stand in every room to illustate to me how effective it is ![]() . His garage is big enough...he just can't get his beloved wife to get on the same page he is (re neatness and organization) in order to clear enough room. They're originally from Chicago (suburbs)....so, very in touch with 'keeping warm in the most efficient manner possible'.
#10 | |
The pellet stove really is amazing. We bought it to make use of the fireplace and to have a place to warm the buns. In the first couple of weeks of using it from when we woke up until we went to bed, I noticed a significant drop in heating oil consumption, so we started running it 24 hours/day. In that mode I found that 1 ton of pellets equaled a 275 gallon tank of oil for 1/4 the cost. Last winter was super cold and long and we burnt just over 5 tons of pellets. We ran out towards the end of heating season and had to scramble to find a few bags here and there. This year we bought six tons to make sure we don't have to do that again.
#11 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
My concern with this kind of setup is the torsional (roll moment) loads that it can generate on the receiver, and the tongue weight. I went with the internal solution and found a nice big rubbermaid bin that fits in the cargo area with the rear seats slid forward.
#12 | |
#13 | |
. Do you know of any retail STORE (that has a location in TX, NM, AZ or CA...or even in Las Vegas) that sells them individually, not by the 8 pack ?
#14 | |
#15 | |
#16 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Nice cans you got there
#17 |
And, here's another advantage of using the Yaris in place of the Tacoma: FREE dump runs.
I pulled out a set of built-in bookshelves recently and needed to dispose of them. I decided to load them into the back of the Yaris, rather than using the carrier, as it was a lot of pieces of wood. We get charged by volume to dispose of items other than recyclables or household trash at our recycling center, and normally a run like this would run somewhere between $25 and $40 depending on which dump dude looked at the truck and estimated the volume. With my short bed Tacoma, this would have looked like a lot of material, so chances are that I would have gotten dinged the $40. With the Yaris, I tell the dump dude that I have a book shelf in the back to dispose of and he looks at the car and says "In the back of that little thing?". I say yes and he says "It can't be very big to fit in there. No charge". Little did he realize that this is what was back there: Yaris - Dump Run.jpg
#18 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() First they cut peoples heads off on TV and now THIS! (could this be the doing of the terrorists?)
| Tags |
| carrier, hitch |
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
| How to turn ON Yaris Maintenance Required light? | JohnnyRockets | DIY / Maintenance / Service | 11 | 12-14-2012 10:36 AM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
| Ohio Yarii owners: Turn in Concepts needs a Yaris to measure! | schleppy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 04-17-2009 04:20 PM |
