Old 10-07-2014, 11:30 PM   #1
Ben_
Drives: 2010 Yaris Hatch
Sway bar swap
Has anyone found a rear sway bar from another car that fits 2nd gen yaris's? I'm assuming aftermarket is the way to go, but you never know what will pop up
Ben_ is offline   Reply With Quote
Old 10-08-2014, 05:46 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
At the price of a new TRD rear sway why bother they have dropped in price so much but to answer ur question ..its something that would require lots of modifying cos so far have not seen anything that would just bolt on from other cars.
sent from my S4 on Mars
Old 10-08-2014, 08:52 PM   #3
Ben_
This is too bad. If there was a bar that could swap from the junkyard I would have bought one and put it on for this years auto x season. Maybe someone else will chime in on a possible lead. Some other small fwd car that comes stock with a rear bar like a corolla
Old 10-08-2014, 09:04 PM   #4
If you look at the rear axle beam and how the rear bars work, I strongly believe that you could simply weld a piece of steel to reinforce the spring perch and would achieve exactly the same effect with less weight.
Old 10-08-2014, 09:22 PM   #5
Ben_
I see what you are saying. It would appear to work, but would not be reversible without some serious work.
Depending on the geometry used, welding a pipe with no bends would almost make the suspension not move at all left to right
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 09:47 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
