Old 10-08-2014, 03:42 PM   #1
07stlYaris
If Its Not Blown It Sucks
07stlYaris's Avatar
Drives: 07 Yaris LB Meteorite
Idler pulley for Blitz??
Anybody have a generic part number for an aftermarket idler pulley for the Blitz supercharger? Not the clutched pulley, the idler pulley that comes with the kit. Mine is making a little noise.
07stlYaris is offline   Reply With Quote
Old 10-08-2014, 06:15 PM   #2
Contact Micro Image, as they tend to have some spare for the Blitz kits. If he doesn't have one, pull the pulley off and take some measurements of the bearing (or go to a local bearing shop) and you should be able to find an off the shelf replacement for it.
Old 10-09-2014, 09:43 AM   #3
07stlYaris
07stlYaris's Avatar
Noticed the bearing is clipped in. I'll try the bearing route. Any thoughts on the need for the ridges on both sides of the pulley? If I do replace the pulley, I doubt too many aftermarket or OEM for other vehicles will have those.
Old 10-09-2014, 10:01 AM   #4
That's a good question. I would think that the ridges should not be necessary, since the water pump pulley not just doesn't have them, but actually has a rounded edge.
Old 10-09-2014, 07:07 PM   #5
Don't have a spare idler pulley, already sold that out of the parts kit - sorry
Old 11-11-2014, 05:57 PM   #6
MUSKOKA800
MUSKOKA800's Avatar
I removed mine, popped out the circlip, knocked out the tired bearing and sourced a new premium bearing from an industrial supply house for under $20.00.
The original bearing had gone dry. After twice repacking it I decided a new one was in order.
Old 11-11-2014, 07:56 PM   #7
Do you have the bearing part number that you went with?
Old 12-06-2014, 04:58 PM   #8
MUSKOKA800
MUSKOKA800's Avatar
Sorry, can't recall offhand however it was the same code marked on the side of the original bearing. It was not a typical/stock item due to high temp seals so it was a couple days delivery to the industrial supply house.
DC header, AEM cai and MI lightweight crank pulley install aspro Performance Modifications 7 09-02-2014 06:57 AM
Explain: NST Underdrive & MI pulley evo165 Performance Modifications 14 01-08-2014 02:18 AM
FS: NST 20% Overdrive Alternator Pulley MGargano Items for Sale by private party 12 06-05-2011 11:06 AM
FS: 2009 Alternator & Overdrive Alt. Pulley MGargano Items for Sale by private party 9 10-28-2010 07:42 AM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 02:51 AM
