Old 10-14-2014, 11:54 PM   #1
BoostedTRD
Drives: 09 Yaris Hatchback
How do prevent CEL after turboing your yaris
I will be going turbo soon and wanted to know how to prevent CEL. When I had my turbo Honda I used a MAF sensor to trick the ecu and hondata also helped. So what did you guys use?
BoostedTRD is offline   Reply With Quote
Old 10-15-2014, 10:56 AM   #2
kou
Drives: 08 lb
You should not have a check engine light on after going turbo. If you remove the stock cats you will but can easily be fooled by moving the o2 sensor out of the exhaust stream a little.
Old 10-15-2014, 11:56 AM   #3
BoostedTRD
awesome info. Thanks man
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
