Old 10-20-2014, 04:21 PM   #1
misterno
Drives: Man
Send a message via ICQ to misterno Send a message via AIM to misterno Send a message via Yahoo to misterno
How to listen to music from Nexus 4 (LG) thru AUX in 2009 Yaris?
I have 2009 Toyota Yaris which has the AUX input jack not on the radio but on the right side down.
I want to listen to music from Nexus 4 which is an LG brand, by plugging into this AUX.
My radio has the AUX option.
But when I checked ebay and amazon I was not able to find a cable that is suited for this job. Can someone help?
misterno is offline   Reply With Quote
Old 10-20-2014, 04:48 PM   #2
The aux jack is a 1/8" stereo headphone jack, so you should just need a male to male cable, which you can get at Radio Shack, Best Buy, etc.
Old 10-20-2014, 05:17 PM   #3
misterno
Drives: Man
So let me get this straight
The jack that goes into my car's aux will be 1/8" stereo headphone jack
How about the one that goes into my Nexus 4? 3.5mm I guess
so are they selling male/male cable like that?
Old 10-20-2014, 06:10 PM   #4
AFAIK, 3.5mm is about 1/8th inch.
Old 10-20-2014, 06:41 PM   #5
Correct - 3.5mm is the same as 1/8". The cables can be labeled either way. I bought one in Radio Shack recently and it was labeled as 1/8", but they also had some crazy colored ones that were labeled as 3.5mm.
Old 10-20-2014, 06:58 PM   #6
Kar98
Drives: 2011 Scion tC
Aka "male to male headphone cable".
Aaaaand that brings me back to the first time I asked for something like it and nobody knew wtf I was talking about and what its purpose could possibly be. Radioshack, Denver, ca. 1999.
Anyway, be aware that the aux in jack in your Yaris is not amplified so you need to crank up the volume on whatever device you plug in.
Old 10-20-2014, 09:52 PM   #7
Exactly. Now they carry at least 10 different ones ranging from $9 to $25. The retractable ones are pretty handy:
Old 10-21-2014, 06:26 AM   #8
misterno
Drives: Man
Seems like both ends are same size jacks is this correct?
Also should choose one over another to improve sound quality or are they all same?
Old 10-21-2014, 06:40 AM   #9
Correct - Both ends are the same. The difference in sound quality from one to another would be nil.
Old 10-22-2014, 09:11 PM   #10
mitchell12
mitchell12's Avatar
Drives: 2007 yaris HB
I needed one a long time ago and they used to be called line in cables or you could get them at Pc stores for the speakers going to the amplifie. The worst one I ever had to make work was using a 1/4 inch mic wire with 2 3.5mm adapters on either end lol.
mitchell12 is offline   Reply With Quote
Old 10-22-2014, 09:40 PM   #11
Kar98
Right, "line in cable" was the other name for it. My first CD player had two 3.5 mm out jacks, one was for headphones and powered, and the other one was labeled "line out" and unpowered because it didn't need to drive headphones and expect the system it got plugged into to provide power. Which the car stereos I had in the Europe of the '90s did. Advantage? You could keep the discman running on a pair of AAs for many more hours because it didn't need to provide an amplified signal, just a signal.
I guess that wouldn't work at all with the standard aux-in jack on a Yaris.
Old 10-23-2014, 06:01 AM   #12
If you ever plugged a headphone into one of the "non powered" ports, you'd find that it is just the same as the headphone jacks but without volume adjustability. Ie, max volume.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Is extended warranty (6 yrs/75,000 miles) worth it for 2009 Yaris sedan? Marls General Yaris / Vitz Discussion 5 05-29-2011 11:23 PM
What music to you listen 2 in your yaris? YotaYarisUSA General Yaris / Vitz Discussion 126 04-27-2010 02:23 AM
