Old 11-13-2014, 11:28 AM   #1
Caramanos2000
Drives: 2012 Yaris 5dr Hatch
Anyone know if 15x8 0 will fit 3rd gen?
Im trying to figure out if 15x8 0 offset will fit a third gen without rubbing. I want a nice set of wheels but im looking to maintain a daily ride. If these wont fit I guess id probably go 16x7
Caramanos2000 is offline   Reply With Quote
Old 11-13-2014, 12:57 PM   #2
Those will absolutely not fit. Offset is the key. 0 will poke out like crazy and you'll be buzzing your fenders non-stop. on a 7 inch wide wheel, an offset of about +35 is about as far as you can go.
Old 11-17-2014, 06:05 AM   #3
alias06
Drives: 2008 Red Toyota Yaris
I am running XXR 522s 15x7 +20 on my Yaris hatchback stock suspension and have no rubbing issues. I'd say that the rear fits flush or close to flush while the front sticks out slightly. 0 offset will definitely stick out further and will most likely rub.
alias06 is offline   Reply With Quote
Old 11-17-2014, 06:22 AM   #4
People who run +20 and say there is no rub obviously do not :
- carry passengers and/or cargo
- hit bumps and potholes
- drive and high speed over road dips and rises
Old 11-17-2014, 06:34 AM   #5
alias06
I daily drive the Yaris and use it to commute my family of 4 everywhere, the trunk is always full of something either groceries or stuff, it doesn't take much. The roads here aren't always pretty so there are plenty of bumps/dips/etc. I don't try to hit bumps or potholes and don't personally know anyone does does it purposely but the ones that I have gone over haven't caused any rubbing. I did list offset wrong at +20 though, it isn't and is actually +25.
Old 11-17-2014, 08:58 AM   #6
+20 is probably ok on stock high though.
Old 11-17-2014, 09:13 AM   #7
I've run +32 on stock height. Under high spring compression I buzzed the inside of the rear fender arch. That was with 195/50 on 16x7.
Old 12-16-2014, 10:38 PM   #8
WorkTL
WorkTL's Avatar
Drives: 2013 Yaris LE
I run 15x8 +25 lowered on DF210's. Not even close to rubbing. Getting 15x9 +0 next.
WorkTL is offline   Reply With Quote
Old 12-17-2014, 09:39 AM   #9
Not exact to your offset but gives you an idea of what is available. I run 15x8 +26 in the rear 15x7 +26 in the front and lowered 2". Hard dips and potholes I do hit the rear fenders. The front has no issues at all.
What suspension are you running that you are not hitting your fenders?
Old 12-17-2014, 09:49 AM   #10
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I'd imagine that he's also using very low profile tires, something with an overall diameter of 23" or so. Stock is about 24".
Old 12-17-2014, 09:49 AM   #11
G-Ammo
G-Ammo's Avatar
Drives: Toyota Yaris 2009; 1.0 3 Cil.
Running 15x8 offset 25 with 20mm spacers in the back, it rubs a bit when taking speedbumps or strange hops in the road... but thats it, all depends on what tyre you put on :)
Front 15x8 offset 25 with 195/45/15 tyre = no rub, nothing, only rear a bit.
Speedbumps suck...!
G-Ammo is offline   Reply With Quote
Old 12-17-2014, 10:12 AM   #12
coheed
Drives: 08 BB LB
You also have to consider camber. Yes with factory spec camber, lowered with 15x8 +20 you'll be killing your fenders. But my 15x8 +20 wheels never rubbed, neither do my 15x7 +36 with 25mm spacers. But I was running -4° camber all around and rolled and pulled my fenders. You will HAVE to roll fenders and possibly add neg camber to get aggressive offsets to work.
Old 12-17-2014, 10:25 AM   #13
wildmongoose26
wildmongoose26's Avatar
Drives: 09 5dr Yaris
16x8+0 on the rear for reference
Old 12-17-2014, 12:01 PM   #14
coheed
Drives: 08 BB LB
^^ How much camber were you running? And was that before you had the fenders pulled?
Old 12-17-2014, 12:08 PM   #15
wildmongoose26
That was no fender work and no camber.
Old 12-17-2014, 03:42 PM   #16
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
I've run three sets of non-aggressive wheels and all have rubbed when lowered on Tein S-Tech under full compression. The rubbing happens on the driver's side only. It's worn away part of the inner fender liner. FYI, I have a 2007 liftback. Not sure if the fenders changed much.
16x7 +37, 205/50/16
15x7 +40, 195/55/15
15x6.5 +40 195/55/15
I can't imagine running a 15x8 +25 up front. I might as well remove the fender liner.
Old 12-17-2014, 05:54 PM   #17
I'm always baffled when people running these offsets in the 20s claim they do not rub. Always baffled.
Like Thirty-Nine, I've rear rubbed with two sets of non-aggressive setups. It is impossible not to rub with these setups being talked about when under high spring compression.
Old 12-26-2014, 05:00 PM   #18
WorkTL
WorkTL's Avatar
Im telling you...I have zero rubbing. I run stretched tires.
AFE short ram intake in 3rd Gen DJYojimbo Third Gen Yaris General Discussion 10 12-20-2012 09:25 PM
July 3rd Mosport DDT Track lapping event (Sunday) -9th event of 2011, 1pm-5pm Touge.ca Canada 0 06-23-2011 02:53 AM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 09:18 PM
Test drove: Yaris sedan 5spd, Fit base auto, Civic LX 2dr 5spd Bounty Hunter General Yaris / Vitz Discussion 7 07-11-2007 07:40 AM
