Old 11-21-2014, 10:09 AM   #1
Eduardo_mty
help: i will install Curt 56175 wire converter
2015 yaris hatchback
What and how should I remove the pieces of the trunk to install the curt 56175 wire converter, to avoid damaging any parts..
how i will connect this wire converert.
Eduardo_mty is offline   Reply With Quote
Old 11-21-2014, 01:44 PM   #2
ucsmfu
Drives: yaris le
what is this wire converter for ?
ucsmfu is offline   Reply With Quote
Old 11-21-2014, 02:13 PM   #3
Eduardo_mty
i iwll use with this, becouse last time when i visited USA, one car "crash" my cargo carrier, and he said "i dont see it"
Old 11-21-2014, 02:38 PM   #4
To wire up the taillight converter:
Brake: Light Blue (either side)
Left Turn: Yellow (Left Tail Light)
Right Turn: Sky Blue (Right Tail Light)
Tail: Green (either side)
Ground: White/Black (either side)
Old 11-21-2014, 02:47 PM   #5
Eduardo_mty
Thank you CTScott, i will need remove all plastics from rear trunk?
Old 11-21-2014, 02:55 PM   #6
Eduardo_mty
i will tap, from left side of the car ?
Old 11-21-2014, 03:58 PM   #7
Either side, but you will need to run one wire over to the opposite side. You should not have to remove all of the plastics. You can open the hatches for access to the lights and then feed the wires down into the spare tire area. For exiting the car, the rubber plug at the bottom of the spare tire well is better than drilling a hole through metal.
Old 11-22-2014, 09:06 AM   #8
428CobraJet
Drives: '09 Yaris 3dr, 13 F150rcsb 5.0
Did you get the trailer hitch to fit your 2015?
You are what you drive.
428CobraJet is offline   Reply With Quote
Old 11-22-2014, 09:07 AM   #9
Eduardo_mty
Was "custom" made.. I upload picture An a moment
Old 11-22-2014, 09:28 AM   #10
Eduardo_mty
i live in México, and i cant go to USA before my trip..
a welder man, did my "custom" hitch....
Old 11-22-2014, 09:30 AM   #11
428CobraJet
Beautiful!
Old 11-22-2014, 09:32 AM   #12
Eduardo_mty
Originally Posted by 428CobraJet View Post
Beautiful!
thank you
Old 11-22-2014, 09:51 AM   #13
That does look good. It is quite low though, so you will have to be careful to not scrape your carrier.
Old 11-22-2014, 09:52 AM   #14
Eduardo_mty
The carrier will be modify.. Maybe today i will go for it
Old 11-23-2014, 07:59 PM   #15
Eduardo_mty
today i was installed the wire converter, but the right light do not work
see pict.
any help it will be appreciated
pict from left to right
left side, right side (green/yellow wire) in both sides where the light bulb are installed
right side "close up" (both pict)
green wire from left to right... 4 pin connector to "floor" outside the car
last pict.... box controller
Old 11-23-2014, 08:12 PM   #16
Does just the right turn signal not work, or do none of the functions work on the right side?
Old 11-23-2014, 08:18 PM   #17
Eduardo_mty
the tail light in the car work, but in the curt wire dont
Old 11-23-2014, 08:27 PM   #18
I figured that was the case, but through the curt, does everything except turn signal work on the right or does nothing work on the right?
Help me install my Infinity Basslink! wsladaritz In Car Entertainment + Electronics (audio / video / alarm) 17 10-21-2008 12:15 PM
Help me install a converter to HU wsladaritz DIY / Maintenance / Service 8 09-07-2007 06:54 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
