Old 11-22-2014, 01:01 PM   #1
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
Cool wonderin ignition switch anyone ?
I have a 2010 sedan, but we all got the same ignition switch, 2nd gen, I would assume.
I noticed, when I get out, the door locks unlock again (AFTER TRYING TO LOCK) as if the key is still in the ignition.
I also notice, the radio at times stays on longer, even with the door open.
I haven't diagnosed it yet (to busy workin), but it screams the electronic portion of the ignition switch is most likely an issue.
This is intermittent, but is annoying and troublesome if the wife takes the car anywhere, as one could leave the car unlocked if not paying extra attention.
ANYONE ELSE HAVING THIS ISSUE AND FIX IT YET ?
sticky ignition switch Yaristeve DIY / Maintenance / Service 1 01-11-2017 01:13 PM
Ignition Kill switch? Deathegg DIY / Maintenance / Service 6 07-05-2011 07:17 AM
Does Ignition Switch ACC provide 12v for remote wire? marco_george In Car Entertainment + Electronics (audio / video / alarm) 7 02-01-2011 11:50 PM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
