Old 11-25-2014, 04:12 AM   #1
Dreamy
Drives: 2008 Yaris Y
Help, disordered fuse boxes (both).
I have a 2008 Yaris sedan, and my brother took it for a few days. I don’t know what was he thinking by going to the fuse boxes and try to mess with it. Now the stereo, cigarette outlet and the license plate light don’t work also the car shakes and I don’t feel its normal anymore.
So I decided to check the fuse boxes and make sure they are in the right order
My question is should I just follow the fuse boxes diagram or what?
Thank you in advance.
Ps: there is no trustable electrician nearby also I prefer to do it by myself.
Dreamy is offline   Reply With Quote
Old 11-25-2014, 06:24 AM   #2
Just follow the diagrams on the covers to put them back correctly. Look at each, as if he put smaller rating ones where larger ones should be they will likely have blown.
Old 11-25-2014, 10:43 AM   #3
Dreamy
thanks CTScott,but if i followed the diagrams and put exactly the same is it normal to have empty slots ?
Old 11-25-2014, 11:31 AM   #4
CoryM
Drives: 2009 5-door, 5-speed
Yes. depending on options and such. May have a few "spare" fuses as well. The best way to check fuses is with a test light to see if they are blown. I would get them all in the right spot, then turn the key and lights on, then check all fuses.
Make sure to smack your Brother to fix the root cause of the problem Family.... gotta love 'em.
Old 11-25-2014, 06:25 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
not sure a smack is enough, a bullet might be the correct response for something like that. Totally insane.
Colin Chapman disciple
Old 11-26-2014, 10:25 AM   #6
Dreamy
well i will try to do it this weekend, hope to fix it, thanks a lot
Old 11-26-2014, 10:27 AM   #7
Dreamy
just if i can do that hahaha
at least i found an excuse not to give him again
Old 11-27-2014, 04:50 AM   #8
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
"a bullet might be the correct response for something like that"
Don't you just love the U.S. phsyche?
mrpj is offline   Reply With Quote
Old 11-27-2014, 08:29 AM   #9
nortonfb
Drives: 2007
Maybe a pointy knife instead?
Got to love that UK logic, eh?
Norton
built by Brits with pointy knives
nortonfb is offline   Reply With Quote
power outlet/cigarette lighter fuse location Idahotom General Yaris / Vitz Discussion 1 01-08-2014 05:45 PM
Blown or missing gauge fuse causes strange symptoms on a 2007 Yaris hatchback vandallen DIY / Maintenance / Service 1 06-06-2013 09:59 PM
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 06:53 PM
Fuse Fix bronsin General Yaris / Vitz Discussion 4 12-18-2011 02:05 AM
