Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 02-01-2015, 02:43 PM   #1
sebastianroher
Drives: 2009 Toyota Yaris Hatchback
HELP!!!
My '09 Yaris won't start! I recently changed the Camshaft Position Sensor because the old one was spewing oil out of it. I went to start the car today and she just cranked over but never started. I pulled all the plugs and she is getting fuel to every cylinder. I checked the new camshaft position sensor and saw about a 1/4 of a tsp of oil in the new sensor as well. I cleaned it with a q-tip and reconnected it but she still won't fire!!! I am going to compression test it today, but I don't know why I'm not getting spark. If anyone knows what I should do/try, it would greatly be appreciated.
sebastianroher is offline   Reply With Quote
Old 02-01-2015, 03:35 PM   #2
sebastianroher
Update!!!
Cylinder 1 Compression: 195psi
Cylinder 2 Compression: 155psi
Cylinder 3 Compression: 165psi
Cylinder 4 Compression: 190psi
Old 02-01-2015, 03:54 PM   #3
It looks like you have a leaky head gasket or warped head on the center cylinders. Considering that it was starting before you replaced the crank sensor, I would check that. I would also check to make sure that each plug is getting spark since you are getting fuel.
Old 02-01-2015, 03:57 PM   #4
sebastianroher
Scott, I replaced the camshaft sensor, should I check and replace the crankshaft position sensor? I shot you a few messages as well.
Old 02-01-2015, 04:00 PM   #5
I would put the original cam sensor back on to see if it starts.
Old 02-01-2015, 04:02 PM   #6
sebastianroher
You think the new one is defective
Old 02-01-2015, 05:02 PM   #7
sebastianroher
Scott, I tried that and I get P351-P354 ignition circuit malfunction
Old 02-01-2015, 06:58 PM   #8
sebastianroher
I pulled the crankshaft position sensor. I'm going to test it at work tomorrow. I don't know what else it could be, I studied the diagram and the crank sensor is in line with the ignition system and when it fails the car won't start or will be hard to start.
Old 02-01-2015, 07:34 PM   #9
0351-0354 can be caused by the Oil control valve not working due to being plugged up. That is the round device mounted next the alternator. It also has a fine mesh filter mounted into the block below it.
Old 02-01-2015, 07:38 PM   #10
sebastianroher
How do I remove it? Do I replace it or clean it and re-install it? What about the mesh filter?
Old 02-01-2015, 07:43 PM   #11
The valve is just mounted with one 10mm bolt. You can pull and clean it. The filter as well you can pull and clean.
Old 02-01-2015, 07:45 PM   #12
sebastianroher
Alllright. I'll work on that tomorrow. What do you think about the crankshaft sensor? I also don't understand how that valve throws off the ignition?
Old 02-01-2015, 08:04 PM   #13
It's worth checking out the sensor and easy enough to do so if you have access to an oscilloscope.
Old 02-01-2015, 09:23 PM   #14
sebastianroher
What's an oscilloscope? I was gonna check the resistance with a multimeter
Old 02-01-2015, 09:31 PM   #15
sebastianroher
The manual you sent me says to check the resistance.
Old 02-02-2015, 12:41 PM   #16
sebastianroher
Scott, I checked the oil valve and it was surprisingly clean. I wiped it down and re-installed it. I'm going to check the crank and cam sensor tonight when I get to work. Where is that mesh filter you were talking about? I couldn't seem to locate it. There was this bolt I'm assuming, it was bolted on below the oil valve. It had an allan key head, and I stripped it out :( do you know what that is?
Old 02-02-2015, 01:06 PM   #17
That bolt into the block directly below the valve is the cover for the filter housing. The filter is about an inch long and 1/4" in diameter.
Old 02-02-2015, 01:07 PM   #18
sebastianroher
Any idea on how to get it out since I rounded it? Also, do they sell them?
