Old 02-19-2015, 04:07 PM   #1
IconBasser
Drives: 2008 Yaris Sedan
Question Rasp/scrape, only when turning right
Hi guys! I own a 2008 Yaris S, currently at 102,000 miles. Ever since I bought it used at 52k, there has been a scraping noise when I crank the wheels all the way to the right. I don't have that problem under any other circumstance.
Recently I've noticed a slight thump if I'm making a hard right from a stop, but only infrequently, like every couple days or so.
I read through the control arm bolt thread and took a peek; they're both there, nice and shiny.
Any ideas?
IconBasser is offline   Reply With Quote
Old 02-19-2015, 04:53 PM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
What is the condition of your wheel liner? The black covering around the wheel well.
Also what are your wheel specs in the front. With mine, i foul/scrape when i go full lock at certain times, because the inside of the wheel scrapes the control arm
Check out my Build thread:
Wheels slipping when hard lock turning - dealer says this is normal? eskiepeskie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-08-2012 08:49 PM
Turning on the a/c caineroad Fuel Economy Forum 31 07-29-2011 11:07 AM
Higher tire pressure=less turning ability?? dchurchwell Fuel Economy Forum 4 05-07-2011 09:56 AM
"Clunk" When Turning KRAZGRL DIY / Maintenance / Service 39 07-30-2010 01:16 PM
2006 Yaris clicking/clunking when turning heistp General Yaris / Vitz Discussion 1 10-13-2009 09:48 AM
