Old 02-21-2015, 01:40 AM   #1
basharalezze
Drives: yaris sedan 2008
check engine again
two days age i drage the sensor was called camshaft timing oil and during the procedure the sensor split into two parts and after that i insert it again but check engine turned on . what is the solution
basharalezze is offline   Reply With Quote
Old 02-21-2015, 08:55 AM   #2
Did you replace the sensor with a new one, or just reassemble the broken one?
Old 02-21-2015, 02:25 PM   #3
basharalezze
check engine again
I collect old, broken
Old 02-21-2015, 05:45 PM   #4
OK. You really need to replace it. It is a solenoid valve, so it is a device which has internal movement when power is applied to it.
Old 02-22-2015, 01:07 AM   #5
basharalezze
check engine again
Please explain to me his role in the car
2007 sedan fuel pump not running and check engine light nitrus10032 DIY / Maintenance / Service 23 08-23-2025 12:09 PM
check engine code P0101 bugg_master Performance Modifications 6 09-24-2016 01:41 PM
engine check light Capsat DIY / Maintenance / Service 1 06-24-2012 01:03 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
