Old 02-25-2015, 09:28 PM   #1
Echo86
Drives: 2003 Toyota Echo
Two Problems
Hi All, it's been a cold winter here in Canada, but the car only recently did not start on the first try. Now I have to delay a few seconds before trying again. Usually it starts on the second try. I can tell the temperature makes it worse. I replaced the plugs and air filter in December. That is it. I checked the ground on the battery. It is secure. That's problem 1. Problem two is the power since repairing the exhaust. It had separated at the muffler flange. I plug welded the pipe together, it wasn't the greatest job and some wire may have gotten stuck in the pipe. The muffler makes a soft whooshing sound when the throttle is release during gear changes. I will do a proper repair with a new piece of pipe later. At least the rattling sound of the exhaust knocking about is gone. Cheers
Echo86 is offline   Reply With Quote
Car wash causing electronic problems? lamadoo DIY / Maintenance / Service 3 12-24-2013 10:47 AM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Yaris problems heavenswaitin DIY / Maintenance / Service 3 11-02-2011 01:08 PM
A few problems drunkwithwords General Yaris / Vitz Discussion 1 04-01-2010 11:13 AM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
