Old 03-22-2015, 12:20 PM   #1
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
Unhappy Clock \ Ambient \ Trip computer not working
Heya Guys !
haven't been on here for a while.
I need some advice, recently my display for the trip \ Temp \ clock
has just stopped working.
It does some days come on and then disappear in a few seconds.
I have went trough the fuses etc. but its only this part.
I don't know what to do any further, its been working until now.
2008 Yaris Hatch
Thanks in advance :)
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 03-22-2015, 07:36 PM   #2
It wouldn't be a fuse, if the rest of the instrument cluster lights up, it would be an internal issue. I would open the instrument cluster and make sure that the small piggyback board is fully seated into the connector on the larger circuit board.
Old 06-30-2015, 06:44 PM   #3
Pingu
Drives: Toyota Yaris 2008, 1.3L M
Did you manage to find a solution? I have exactly the same problem, same year car too?
Pingu is offline   Reply With Quote
Old 10-04-2015, 07:38 AM   #4
grgo
Drives: Yaris 1.4d-4d, 2008.
I have also same problem, same year 2008...
Any solution?
grgo is offline   Reply With Quote
Old 10-19-2015, 03:54 AM   #5
Vitdavkin
i have the same issue for the last 5 months, checked all the fuses and they are fine....any one can please help out with this problem??
Vitdavkin is offline   Reply With Quote
Old 10-19-2015, 06:46 PM   #6
As I mentioned above - Open the cluster and check the seating of the small piggyback circuit board. If that doesn't help, then you are looking at a cluster with an internal fault.
Old 11-05-2015, 09:57 PM   #7
Alex_blount
Drives: Yaris 53 plate 2003
I have the same issues just on a 2003 model. And no power to cd player it was working before same as cig lighter. Any idea what it could be? I can't seem to put it back together. Whats a piggy back board?
Alex_blount is offline   Reply With Quote
Old 11-05-2015, 10:02 PM   #8
Your 2003 is quite a bit different than that of the prior posters. For yours, check the 15A ACC fuse in the under dash fuse panel.
Old 11-06-2015, 06:09 AM   #9
Alex_blount
Is that under the steering wheel?
Old 11-06-2015, 06:15 AM   #10
Yes. On the MK1 Yaris it is in the fuse panel that is below the steering wheel.
Old 08-10-2016, 03:07 AM   #11
Minh
Drives: Yaris Hatch 2008
I registered just to ask. I bought one Yaris 2008 hatchback today and I just noticed I am facing the same issue. Can someone tell me how to make this work or how to reseat the board/connector. Thanks.
Minh is offline   Reply With Quote
External temp. Display & Trip Computer bung206 Performance Modifications 33 07-26-2018 05:18 AM
Trip Computer and External Temperature Display jodiem In Car Entertainment + Electronics (audio / video / alarm) 62 11-15-2012 10:06 AM
Help me pick a trip computer + a question about gas miles per tank bar gabriel2012 Fuel Economy Forum 22 06-07-2012 01:48 PM
