Old 03-28-2015, 11:08 AM   #1
CV/axle nut
I was cleaning my ABS sensors the other day and came across the axle bolt in the front wheels. It isn't your standard bolt, does anyone know how you would go about removing this? It doesn't have a cotter pin in it but an actual indent in the nut. I'd like to know how to remove this incase my hub bearing start to go or if I even need to remove it for any reason.
Thanks
Old 03-28-2015, 04:12 PM   #2
It requires a 30mm socket and a tool for un-denting the part that gets dented against the slot in the axle. I use a tapered, round steel tool that is meant for being pounded to line up bolt holes, etc.
Old 03-28-2015, 05:29 PM   #3
ex-x-fire
Its a 12 point nut, isn't it?
Harbor Freight recently released a big 1/2 drive 12 point impact socket set. It goes up to 32mm. Their pro sockets are very good for the money.
Old 03-28-2015, 06:16 PM   #4
Correct - 12 pt, 30 mm.
Old 03-29-2015, 08:04 PM   #5
thanks for the responses guys. I took a look at CanadianTire today and the only 30mm socket they have was a 6 point. Is a 6 point adequate for a 12 point nut, or does it increase the slippage and potential to strip? If a 12 point is highly recommended then I'll keep looking for one.
My second Q is can you just use an impact gun to remove the nut without having the pop out the indented part?
Old 03-29-2015, 08:06 PM   #6
A six point won't fit on it, and no - you can't just blast the indent with an impact wrench.
Old 03-30-2015, 08:39 AM   #7
Go to Princess Auto. I think they'll have one there.
Old 03-30-2015, 10:34 AM   #8
sheekeebut
Minimalist
Drives: 07 silver sedan
That place is like purgatory for the home mechanic. I go in there for one little part, and the whole day passes before my eyes, shopping cart full of stuff that I don't remember getting.
sheekeebut is offline   Reply With Quote
Old 03-30-2015, 11:57 AM   #9
Hahaha yeah I know eh!
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
trouble with tie rod nut BobTheYaris DIY / Maintenance / Service 3 04-07-2014 07:08 AM
AXEL Nut FrankM DIY / Maintenance / Service 1 07-13-2012 06:29 AM
I CANNOT get the front strut nut off naossoan DIY / Maintenance / Service 10 05-30-2009 03:11 PM
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
