Old 05-18-2015, 03:22 PM   #1
scoobopdan
Drives: 2008 Yaris
how to get the most out of stock rims?
So I hate that I even have to ask this question, but my tires have died before I've saved enough for new rims. So I need to rewrap the stock rims. I'm sure many of you more stock guys will understand my plight - at high speeds the car can sway pretty badly with the wind. I lose slight traction when I'm turning at higher speeds like on a highway. Going over bumps in the city can make my car slide. Etc. I tried searching but didn't find anything that is a specific answer to this - what should I look for/brands/etc to best fix these issues while still sticking to the stock rim? I saw stuff about stretching, which I know nothing about, but I'm pretty sure that wouldn't help.
scoobopdan is offline   Reply With Quote
Old 05-18-2015, 08:11 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Slow down lol
http://www.falkentire.com/tires/car-...x-ze950/s-tire
that is the tires i drive on in the summer ...not stock rims but 15s
Old 05-18-2015, 08:24 PM   #3
scoobopdan
Drives: 2008 Yaris
Man I wish that was an option. I live in Texas where 70mph high over pass turns are a norm. Its like Mario mart here. Do you know if your rim is the same width?
Old 05-18-2015, 08:28 PM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
lol...i drive the crap out of my car , one lower it two rear TRD sway bar and good rubber will help.
You can run the tires i mention on stock rims if u like tho i find for better stability find a rear sway bar i find its the best upgrade one can do.
PS im running 195 55 15s
Old 05-18-2015, 08:30 PM   #5
scoobopdan
Drives: 2008 Yaris
Yup rear sway is the next mechanical purchase. Haven't had much time with the car yet. Thanks for the tire suggestion. Would you say that they're lower than usual tires this size. As in, is there less air
Old 05-18-2015, 08:32 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
lower as in lowering springs ...im on Tein's so about 2 inch drop , as for tire pressure i run little above stock at 35 psi.
Old 05-18-2015, 08:44 PM   #7
scoobopdan
Drives: 2008 Yaris
No it's hard to phrase, but lower as in less air in the tires. Less space from the bottom edge of the rim to the bottom of the tire
Old 05-18-2015, 08:54 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
why do u want less air ? are u saying 55 vs 60 as in profile of tire.
Old 05-18-2015, 09:11 PM   #9
scoobopdan
Drives: 2008 Yaris
There's so much wobble, I'm just trying to do what I can to help prevent it.
Old 05-18-2015, 09:26 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
if u are getting speed wobbel , u may have balance or alignment issue etc best take it to a shop have the car taken for test drive cos it could be lots of things .
Old 05-18-2015, 11:27 PM   #11
sheekeebut
Minimalist
Drives: 07 silver sedan
... ! Wobble?!
As in, feel or hear vibrations, or feel or see shaking/quivering in parts of the car?
sheekeebut is offline   Reply With Quote
Old 05-20-2015, 10:38 PM   #12
xxcanuckxx
Drives: 2015 SE HB
I think what your are saying is you want a stiffer sidewall, and by less air you mean a lower profile tire. As far as I understand it, you need to keep the same outside diameter of the tire to keep everything kosher. So if you want a lower profile, you will need a larger rim, 16,17 or 18. Your option with the stock rims, is to buy a more sporty tire, like was suggested earlier. So get away from the normal passenger tire and grab a sportier model. Also as was mentioned, lowering and a sway bar will do more for the wind drifts and wobbly feeling at speed.
xxcanuckxx is offline   Reply With Quote
Old 05-20-2015, 11:26 PM   #13
You don't have to go bigger rims.
195\55R15 is close enough to stay with the stock rims.
Old 05-21-2015, 09:18 PM   #14
scoobopdan
Drives: 2008 Yaris
Ya I think I'm going to go with 195/55 and see how that does. I'm pretty sure it's the widest you can get on stock yaris rims
Old 05-23-2015, 09:16 PM   #15
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Get a rear sway bar. You will be shocked by how much it solves your problems.
Colin Chapman disciple
Old 05-23-2015, 10:58 PM   #16
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
1000% agreed on that it's night and day differences:)
Old 05-23-2015, 11:38 PM   #17
kimona
kimona's Avatar
Drives: 2014 White VITZ
These sizes will work on the stock steel wheels.
185/60/15 = 23.7 (OEM)
195/60/15 = 24.2
195/55/15 = 23.4
205/55/15 = 23.9
To reduce highway wander, focus on tread design. No aggressive tread patterns and a wide continuous center band work best. With this in mind, as well as silica compound rubber, I've been able to completely eliminate highway wander. I experimented with various tread patterns and with the rear anti-sway bar on and off the car, and it is the tread pattern that corrects the problem.
Old 05-24-2015, 09:29 PM   #18
justjesus
justjesus's Avatar
Drives: 2008 Liftback
KIMONA: what tire did you end up with?
Looking for 15 inch stock steel rims hop Canada 2 01-21-2010 07:18 AM
My review of hankook tires 205/55/15 on stock rims YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 09-30-2009 01:01 AM
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 07:11 AM
WTB stock rims + tires + ScanGauge Tonavi Willing to Buy by private party 5 12-25-2008 11:09 PM
