Old 07-29-2015, 07:54 PM   #1
phyrefighterjay
Drives: 07 yaris sedan
Interior blower motor wiring. Which one is positive?
There are two wires leading into the blower fan. I need to test them to see if power is getting to them....don't want to get them wrong. Which is the positive wire. Blue or black?
phyrefighterjay is offline   Reply With Quote
Old 07-29-2015, 08:54 PM   #2
Black is positive.
Old 07-29-2015, 09:18 PM   #3
phyrefighterjay
Thanks buddy. I think I've got a melted connector. In the meantime...WHY THE F WOULD THEY MAKE THE BLACK ONE THE POSITIVE????!!! Black wires where I come from mean negative!
Old 07-29-2015, 09:40 PM   #4
Not for Toyota. White with a black stripe is negative. Almost all black wires on modern Toyotas are positive.
Old 07-31-2015, 01:30 AM   #5
phyrefighterjay
It was a melted connector plug. I cut the plug and crimped on a couple insulated female connectors. Done. Total cost 1.30. Thanks to you all!
Positive words for the Curt Hitch Tifford DIY / Maintenance / Service 5 06-05-2013 10:42 PM
Where to get ring connector for positive battery terminal? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 7 11-13-2008 11:44 PM
LED positive negative question ASAP Sway84 Cosmetic Modifications (Exterior/Interior) 2 06-21-2007 08:39 AM
Yaris Positive or Negative grounding system? marcus General Yaris / Vitz Discussion 2 04-20-2007 10:25 PM
