Old 08-24-2015, 02:38 PM   #1
NineKyle
Drives: '08 Toyota Yaris
Horn Problems
My horn is not working.. I have browsed endless pages on the Internet and found no solution.. It isn't the wheel because the relay makes a clicking noise, changed the fuse, tried a different horn. Now I'm stuck. Anybody have any suggestions? We did a motor swap on this when I bought it.. Not sure if it was working before or not but certainly isn't now ..
Thanks
NineKyle is offline   Reply With Quote
Old 08-24-2015, 03:34 PM   #2
NineKyle
UPDATE
I put a test lamp on the plug that runs from car to the horn and connected it to my negative terminal on the battery. When I pressed the horn the test lamp lit. This means that it is not car-side that is messing up but horn side. What are the chances of going to pick a used horn off a damaged Yaris and getting another one that doesn't work? Is it possible the plug is making a bad connection?
Old 08-24-2015, 04:12 PM   #3
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Try connecting the + and - of the horn itself to the + and - of the battery. If it makes a sound, the horn is fine, too. Then it's the connection somewhere.
If you go to a salvage yard, you can pick a horn from almost any Toyota - it doesn't have to be a Yaris. Just bring your broken one and compare.
Old 08-24-2015, 04:16 PM   #4
NEexpat
Drives: 2009, auto, 4dr LB
Nine,
Not to blow my own horn.....................................chortle, chortle, chortle.
If it turns out to be the horn, I refer to my thread on my Fiamm El Grande install. If you're going to go to the trouble of replacing the horn spend $20 and get a horn, not a road runner impersonator, jmho.
http://www.yarisworld.com/forums/showthread.php?t=51510.
cheers.
NEexpat is offline   Reply With Quote
Old 08-24-2015, 06:25 PM   #5
The small wire that goes from the harness to the horn is probably the issue. You can pop the plastic holders at the top of the bumper to give yourself enough play to get to it. On one of my Yaris, which had some front end damage before I acquired it, the wire looked to be intact, but it turned out that the wire was broken within the insulation.
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
Problems after horn install Astroman DIY / Maintenance / Service 14 04-07-2014 05:15 PM
follow up on 2010 yaris problems + more problems heavenswaitin DIY / Maintenance / Service 18 09-03-2013 03:47 PM
Bungled horn install, eating fuses. CrankyOldMan DIY / Maintenance / Service 12 05-04-2013 12:05 PM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
