Old 08-27-2015, 01:19 AM   #1
Senseless
08 sedan rear speaker install
I'm trying to install 6x9's in my yaris' rear deck. I took everything apart before realizing I needed to fabricate a mounting bracket. I bought a piece of 1/2" MDF and was wondering if this was going to be too thick to fit under the factory speaker guards
Senseless is offline   Reply With Quote
Old 08-27-2015, 06:39 AM   #2
Im not sure if 1/2" will fit, but 1/4" will.
1/2" seems very thick for the space there is, plus you have to install the speaker on top.
Sent from my A0001 using Tapatalk
Old 08-27-2015, 04:36 PM   #3
Senseless
I made the brackets out of the 1/2" and it worked fine. I wanted to use the stock screws and holes so I had to thin the edges so the screws could reach through.
Does anyone know the part number for the plastic clips that hold the trim panels to the rear pillars? I broke one and lost one putting everything back together.
Old 08-27-2015, 10:08 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
For mine i ended up gutting the factory speaker to leave just the outer ring and i tack welded in the new speakers to that
Kinda random...but i had it all tore apart on a late saturday at my old job (muffler shop)...so i made it happen. Been almost 5 years like that
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-28-2015, 11:52 AM   #5
Senseless
I used the same technique on the front speakers in my chevy cobalt. But I don't have metal working tools so I had to make it out of mdf on the yaris. It was fun but took me a full day.
Missing trim plug? - Sedan - Rear Seat Floor Box CB900F2 DIY / Maintenance / Service 7 02-22-2011 06:29 PM
