Old 08-31-2015, 01:54 PM   #1
rakuman
Drives: 2007 Yaris
Downshifting grinding
I just got a 2007 manual tranny yaris and it doesn't want to shift into 2nd unless I'm going below 25mph does a little grind. down shifts fine below that speed. Is this normal? going UP thru the gears no issues what so ever!
rakuman is offline   Reply With Quote
Old 08-31-2015, 03:21 PM   #2
mario98c
mario98c's Avatar
My transmission was doing the same thing... It was the synchronizer that was worn.
Old 08-31-2015, 03:28 PM   #3
rakuman
Drives: 2007 Yaris
that's what I was thinking how much was it to fix ?
Old 09-01-2015, 01:16 PM   #4
mario98c
mario98c's Avatar
I fixed mine with $350 because I bought an used Scion xB transmission and swapped the input, countershaft and differential to my transmission because the xB has a 4.31 final drive. I also did the whole job myself so no mechanic fees.
Grinding Noise While Turning 09heavychevy DIY / Maintenance / Service 17 04-22-2025 07:21 AM
Grinding noise when turning sharp right roblobstuhh DIY / Maintenance / Service 14 07-08-2015 09:28 AM
Grinding noise in reverse NickNickNick DIY / Maintenance / Service 14 03-15-2013 03:10 AM
ABS?, Grinding Noise When Brakes Are Locked!??? p0pNfr3sh DIY / Maintenance / Service 3 03-03-2010 05:22 AM
Grinding sound from engine area Thsplayer DIY / Maintenance / Service 0 01-03-2010 05:09 AM
