Old 10-31-2015, 07:26 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Question AC bad smell
Hi all,
its getting summer now, so the cold AC is going to be in use.
When the AC is running for quite a while, a bad smells starts to form.
From reading around, its due to some crud in the water tray that gets wet.
Is there an easy way to clean this that does not involve having to remove the entire dashboard to access that tray? I would like to clean it out but dont want to have to spend $400 to get it opened up.
JudgeM is offline   Reply With Quote
Old 10-31-2015, 10:42 AM   #2
You can flush it with a mild bleach solution by pulling the hose out of where it goes through the floor (on the inside front of the front passenger foot well). Cover the carpet with plastic and use a turkey baster to squirt the solution into the hose, and then let it drain back out into a pan. Do that until no more crud comes out.
Old 11-07-2015, 02:02 AM   #3
JudgeM
JudgeM's Avatar
Thanks . Just bought a turkey baster. Will try it out tomorrow.
Old 11-27-2015, 12:49 AM   #4
JudgeM
JudgeM's Avatar
I did this. still have the smell. Do you think something like CarPlan odour stopper will work ?
Old 11-27-2015, 04:34 AM   #5
MyzticZ3r0
Drives: 2007 Toyota Yaris Hatchback
Have to check to see if you have a cabin air filter? It's been known for my car (2007 hatch) to be lacking the cabin air filter so all the debris will be lodged there. If there is one, have you changed it?
MyzticZ3r0 is offline   Reply With Quote
Old 11-28-2015, 10:33 PM   #6
JudgeM
JudgeM's Avatar
Yes. I have the cabin filter and I did change it. The smell only comes when the AC is running for a while, it sometimes goes away.
Old 12-09-2015, 01:11 AM   #7
JudgeM
JudgeM's Avatar
After snooping around a bit, sounds like I am going to have to take that AC drip tray apart and give it a good cleaning. Also even the evaporator. I read that under a recall they changed the evaporator because mold grows on it. Wonder if I ring the dealer here and see if they will cover it ?
Old 12-09-2015, 06:10 AM   #8
It is definitely worth checking with them. To get to the evaporator is a nightmare, as you have to completely disassemble the dash (including the support frame under it) to get the airbox out, to be able to access the evaporator.
Weird acidic smell from vent darkmoon87 General Yaris / Vitz Discussion 4 09-01-2009 07:16 PM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 05:26 PM
Weird smell Midon DIY / Maintenance / Service 4 01-26-2009 08:22 PM
Burning Smell Treyz General Yaris / Vitz Discussion 21 11-24-2008 06:16 PM
Funky smell, should I take it to the shop? death is my gift DIY / Maintenance / Service 6 08-12-2007 10:27 PM
