#1 |
![]() Drives: RZN140 Join Date: Dec 2008
AUX wiring to a Factory Headunit
back story:
my wife used to have a 2009 yaris S sadan AT with ipod connectivity. Great car but i eventually swapped the head to a pioneer unit with BT capability. move up about 6 months or so i put that head unit in my tacoma daily driver/beater. pics attached. i need some assistance on the wiring of the AUX input to the factory headunit. i have done some research but its kinda confusing with the different model cars (liftback vs sedan)and such. if someone could point me in the right direction thatd be great. ideally, i could purchase the a harness that plugs into the head and has the factory AUX input panel. thats probably not gonna happen but i need to know which wires are what so i can get the plug (on the head unit side) then solder my own 3.5mm jack. thanks in advance for the help. Last edited by 2rz-fte; 01-15-2016 at 12:47 PM. Reason: add pics |
is this the ticket?
http://www.yarisworld.com/forums/showthread.php?t=9852 i need to purchase a male 20pin connector and a factory AUX adapter? |
#3 |
The jack next to the two blue connectors is the AUX jack.
On that jack 15, 16, 17 am 19 are used for the AUX jack 15 - ALI (left) 16 - ARI (right) 17 - ASGN (signal ground) 19 - AUXI (Switch input from OEM jack to enable AUX) Looking at the back of the radio with the radio positioned as in your second picture, on the bottom row from the left the pins go - 20, 19, 18, 17, 16 ....
#4 |
So it seems that I need to pick up a 20 pin connector and wire it up. But I've read that the impedance across the contacts is very specific. If I wire a standard 3.5mm then I'll have to use a 2k ohm resistor but if I use a stock aux jack then I'll be fine.
Can I use any Toyota or scion jack? |
#5 | |
| factory speaker wiring question. | Domosofly | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 06-25-2011 12:35 AM |
| WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack | zerosktz | Willing to Buy by private party | 4 | 02-19-2011 02:41 PM |
| Tapping into the aux wiring | stanger454 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-04-2010 09:08 PM |
| diy factory aux location with aftermarked hu | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-28-2008 10:38 PM |
