Old 01-19-2016, 10:41 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Question TTR 2015 Setup Dyno Numbers?
We will be hitting the dyno in the morning. We plan on doing both a street tune and a racing tune.
A quick over view of the updates that transpired during 2015:
1) New equal length turbo manifold
2) Increase in IC piping size from 2" to 2.5"
3) Upgrade from MicroImage Golden Eagle Long Runner IM to custom short runner IM with 80mm inlet
4) DBW to Cable Throttle conversion
5) TB upgrade from 54mm to 76mm
6) Upgrade from CCI Stage III 4 puck clutch to ACT Stage III 6 puck clutch
7) Upgrade from OEM radiator to 3 core half width radiator
8) Upgrade from HKS SSQ4 BOV to Tial 50mm Raceport BOV
9) Tegiwa Engine Torque Damper
10) TRD Dogbone engine mount
11) full 3" exhaust with Vibrant UHO GESI cat and Virbant high performance shortie inline muffler
We will be performing the pulls on a Mustang dyno therefore the numbers will be more "real" than with a DynoJet. If not familiar Mustang usually returns 10-12% lower numbers.
We are shooting for around 18psi on the street and 25-28psi with c12 racing fuel.
Do we have any guesses as to what numbers we will see?
Old 01-20-2016, 01:57 AM   #2
LTHatch
Drives: 2013 Yaris Hatchback L
18psi on 91/93: 290-310fwhp C12 @28psi: 420-430fwhp
I'm curious how that ACT clutch will handle that kind of torque your new setup will put out.
LTHatch is offline   Reply With Quote
Old 01-20-2016, 10:00 AM   #3
fnkngrv
fnkngrv's Avatar
First time ever she has been on the scales. Have to reduce the weight by whatever my subwoofer box weighs. More than I was figuring, but with the added weight of the turbo, associated components, etc I suppose I can't complain.
Sent from m-o-b-i-l-e
Old 01-20-2016, 08:04 PM   #4
fnkngrv
fnkngrv's Avatar
Will have more to post, but the short version is we discovered my wastegate is now too small and the day was pretty much a bust due to somehow having a dirty bit of fuel.
Did make 315whp on street gas though with conservative timing.
Old 01-25-2016, 08:32 AM   #5
LTHatch
315 on pump is bad ass, i assume it was at the 18 psi you were aiming for? The real impressive bit is how you sized the turbo, 4k rpm of full torque, that is awesome!
Would like to revise my current guess on your c12 race tune, 440-450fwhp on a mild tune.
Old 01-26-2016, 09:51 PM   #6
fnkngrv
fnkngrv's Avatar
19psi at 12.5° of timing so the timing is pretty conservative.
Old 01-30-2016, 03:41 PM   #7
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Any trans modifications?
Old 01-30-2016, 03:44 PM   #8
fnkngrv
fnkngrv's Avatar
No internal modifications. Only the clutch and flywheel. Using OEM throwout bearing.
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 12:01 AM
TTR Yaris Turbo 2015 Updates fnkngrv Forced Induction Forum 199 05-07-2016 09:54 PM
2015 Yaris SE (m/t) - Week-One Impressions - The Good, The Bad, & The Ugly. Kalispel Third Gen Yaris General Discussion 53 04-29-2016 10:35 AM
Dyno results PETERPOOP Forced Induction Forum 28 12-09-2009 11:01 AM
