Old 01-26-2016, 01:17 AM   #1
AOR 1-1
Scraper
Drives: '08 Yaris RS 5-Door
Camber Bolts
Looking at running some negative camber up front come summer. What options are out there and which will get me the most aggressive camber? Looking for around -5 degrees if possible.
Thanks.
AOR 1-1 is offline   Reply With Quote
Old 01-26-2016, 01:25 AM   #2
my07ty
Drives: 2007 Yaris Sedan
I don't have much experience with camber bolts but iirc each bolt only gets you roughly 1° , and you can only use 2. May have to look into an adjustable top hat from Cusco(or equivalent) to get the 5° you're after.
my07ty is offline   Reply With Quote
Old 01-26-2016, 04:16 AM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I run the TRD Camber bolts. Think the max you can get is just under 3*. If you want more, you may need to elongate the camber bolt hole in the strut. I don't recommend doing this. Maybe some more research out there will help. A lot of the camber bolts are interchangeable between toyota cars with same designs.
-Derrick-
Old 01-26-2016, 01:29 PM   #4
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
+1
Old 01-26-2016, 02:04 PM   #5
Jason@SportsCar
A pair of SPC bolts (upper and lower hole) should be good for around -4 if you have lowered your car some. Much of anything over -3 to -3.5 is excessive and doesn't do much for you unless you are in to that "look".
http://www.spcalignment.com/spc-performance
Old 01-26-2016, 10:40 PM   #6
CoryM
Drives: 2009 5-door, 5-speed
I'm guessing you've never tried two? I'm just curious if two skinny bolts would handle track-days or not. It's general considered unsafe to have two skinny bolts in there.
One SPC bolt will give -2.8° btw. I can't see needing any more than that for performance.
Old 01-26-2016, 11:09 PM   #7
Jason@SportsCar
I currently run a pair of SPC bolts in each strut, a single bolt will not give you -2.8... A single bolt has a range of +1.5 to -1.5 (that is from zero), it requires two to get more. I have never had them slip in normal use.
When we first built the B-Spec cars we used two of the smallest OE crash bolts in each strut, was good for about -2, never slipped.
Even with this hit, which broke the wheel, the bolts did not fail - although they did slip, so I replaced them, along with the control arm, spindle, axle, ect.
Old 01-26-2016, 11:25 PM   #8
CoryM
Good to know they don't slip (except when stuffing it ).
Odd. I got -2.8° out of just one bolt on my 09 5dr (and shifting subframe/ctrl arms).
Cheers.
Old 01-26-2016, 11:27 PM   #9
Jason@SportsCar
Cheers.
Your end number may have been -2.8, but it did not come as the result of a single bolt. The alignment starting point, moving items (as you mentioned) and ride height changes also impact the final number.
I did not stuff it, a CRX tried to ride shotgun. Watch from the 46min mark: http://www.scca.com/videos/1972492
WTB: Adjustable camber bolts and rear camber shims Supra_Yaris Willing to Buy by private party 6 03-21-2015 06:16 PM
anyone currently running two sets of camber bolts? DeathBeard Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-06-2013 01:37 AM
adjustable camber bolts? b20vteg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-22-2012 10:08 AM
Adjustable Camber Bolts Kendrik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-31-2011 02:29 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
