Old 02-01-2016, 10:38 PM   #1
lax2229
Drives: yaris 2007
ABS light on. Help.
The other day I had to press my brakes hard suddenly and right after my abs light came on. I thought maybe it was just letting me know that my abs brakes were just enabled but my light will not go off. I reset it twice via scan tool but after about 10 seconds of no light, it comes right back on. It is ONLY my abs light. I took it too toyota and they said its either my wire or my sensor in my front left of the vehicle and want lots of money. Any help is extremely appreciated. Why is it all of a sudden broken from having to actually use my brakes ??
lax2229 is offline   Reply With Quote
Old 02-02-2016, 08:01 AM   #2
nortonfb
Drives: 2007
They go bad. Can be damaged by road debris. Plug and play install.
nortonfb is offline   Reply With Quote
Old 02-02-2016, 08:42 PM   #3
lax2229
Drives: yaris 2007
Do you know I replace my sensor am I only required to take my wheel off to get too it or my brakes and rotors as well?
Old 02-02-2016, 10:20 PM   #4
BLKHILLSGUY
Drives: 2011 3dr LB Polar White
How much did they want?
BLKHILLSGUY is offline   Reply With Quote
Old 02-03-2016, 07:52 AM   #5
nortonfb
Drives: 2007
No lift here, so wheel always comes off. It's a good time to check the brakes also.
Old 02-03-2016, 08:32 PM   #6
lax2229
Drives: yaris 2007
Not sure what you mean by when I asked if I can remove my sensor without removing brakes/rotors? Maybe I have to remove tire only? Thanks.
Old 02-03-2016, 09:02 PM   #7
lax2229
Drives: yaris 2007
Old 02-03-2016, 09:35 PM   #8
nortonfb
Drives: 2007
If you can get to the back of the hub area, look for the sensor cable.
I find it easier to remove the tire and get a light in there but you may be agile enough
to lay on the ground.
I never replaced one on the Yaris but I have on others.
Should just plug in on both ends.
yaris abs brake light speedometer and electric powersteering issues dave van muyden DIY / Maintenance / Service 4 10-26-2013 02:33 PM
Resetting abs light on 58 plate yards jackg205 DIY / Maintenance / Service 1 06-24-2013 06:43 AM
HELP / Spoiler connecting light SimTronik DIY / Maintenance / Service 4 11-02-2010 11:08 PM
Parking Light Flash Output vs Hazard Light Output sex DIY / Maintenance / Service 2 11-03-2009 08:47 PM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
