Old 02-06-2016, 05:36 PM   #1
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
Easy oil filter access
I haven't changed my own oil in any of my cars since the mid 1980's. When the Jiffylube type places came out it became no longer worth the hassle.
... and no, I've never had a problem with any of the quick lube places ... guess I've been lucky.
This design makes access look super easy -- I might go back to doing it myself.
Old 02-06-2016, 07:57 PM   #2
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
It's the first thing I noticed when I looked under the car at the dealer! Believe me, it's a breeze...I don't even have to jack the car up to drain the oil. I take my time and it only takes 15 minutes or so...it's wonderful.
yougojay is offline   Reply With Quote
Old 02-07-2016, 12:25 AM   #3
I've got a socket for the oil filter. Make loosening and tightening as easy as turning a ratchet.
Old 02-07-2016, 07:10 PM   #4
MadMax
MadMax's Avatar
Quick oil change places may be convenient, but they're not trustworthy.
An oil change on the Yaris is a piece of cake, and will save you a lot of money!
Old 02-07-2016, 07:26 PM   #5
Just do it yourself, that way you get a good look under your own car every 8k km
Old 02-07-2016, 08:38 PM   #6
bronsin
bronsin's Avatar
Hope you take your own advice!
Oil Pan removal to access Piston rod bearings tmontague DIY / Maintenance / Service 5 07-19-2021 11:45 AM
Yaris 2010 oil filter change Carryduff UK 3 04-18-2015 12:05 PM
Any benefit to changing just the oil filter? bairjo DIY / Maintenance / Service 17 10-05-2014 07:21 AM
Longer Life Oil Filter? Yar Is Word DIY / Maintenance / Service 14 07-19-2010 06:35 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
