Old 04-01-2016, 09:41 PM   #1
LeeS17
Drives: Yaris 08 Hatch - No equip
HSD Monopro coilovers
Did someone have ever try these coilovers (HSD Monopro)? I can get them for a reasonable price and I'm looking for user reviews.
Thanks!
LeeS17 is offline   Reply With Quote
Old 04-04-2016, 04:41 PM   #2
LeeS17
Look like they do for some reason. I will try them and give the feedback as soon as possible.
Here a link I found from them online. It isn't the same store I bought them from but it is the same product.
The model number is : HSDT26
I guess I'm a guinea pig.
Old 04-05-2016, 10:58 AM   #3
Appears they are out there for this platform.
http://www.amp-motorsports.com/hsd-s...p91-2007-2012/
I'd like to know what OPs reasonable price is.
Old 04-05-2016, 06:59 PM   #4
LeeS17
They were around 1000$ for the kit at a local part shop and it was what I was ready to pay for coilover.
I got the coilover today so here some early picture of them. I will install them this weekend, get my alignment monday and post final picture mayde monday or tuesday.
I will try to get some picture of the installation and do a before after. I dont know how much I'm ready to drop it but one thing is certain, it must not rub.
It will be my first suspension work and the outside temperature anounce is around 0*C (~32*F). It will be cool
~Lee
Old 04-06-2016, 05:53 PM   #5
LeeS17
They will be installed during the weekend and I hope to show you the result around monday after the alignment
~Lee
Old 04-08-2016, 10:47 PM   #6
LeeS17
Do I need to reuse the existing top hat or just the rubber with whar you are seeing on the picture?
Also, I have no idea where they are made.
Old 04-10-2016, 10:41 AM   #7
LeeS17
Exclamation
They are now installed and i figure everything. Now i need to find why my rear spring dont set flat in the socket. If you have an idea, I would like to know.
Also, i'll be ajusting the ride heigth today and the alignment is tomorrow.
~Lee
Edit : I figure out what to do to fit the spring correctly. I took a quick ride and it is really bouncy, like if I didnt have any damper. I need to find how to adjust it. I will post picture after the alignment.
Old 04-10-2016, 08:54 PM   #8
LeeS17
Question
Ok, after an other small ride, it look like I don't have any suspension at all. The dampers look like the are lock. Did I need to unlock them in any way?
Old 04-10-2016, 11:11 PM   #9
did you try and compress them with no springs out of the car before installing?
Old 04-10-2016, 11:21 PM   #10
LeeS17
I didn't really try but I thought that they may move once install... I was wrong. but I still dont know what is wrong
Old 04-13-2016, 09:01 PM   #11
LeeS17
Ok, rookies mistake where made. I adjust the strut length before installing it and I put it so short that it wasn't even close to compress. I finally found the general installation manual over hsd-usa.com and more information. You can see in there calalogue the Toyota Vitz coilovers and many more car, more than the euro HSD website.
I got a new alignment rendez-vous in a week. The alignment shop is busy this time of the year because of people switching to summer tire.
The only problem I have so far and I need to figure out if I have a way to fix it is that I can't lower the back of my car to have the same wheel gap that I have in the front. Before installation, I had around 124mm all around and.... I lost my current mesurement... I need to take make new one, damn, but it was like 55mm in the front and 83mm in the back but my front wheel have alot of camber (really not align) and it can mess why my mesurement.
I think I will do a general list of what I had to do to fit the coilovers on the car. It could help people because I had some minor suprise.
Thanks for the help
~Lee
Old 04-14-2016, 07:37 PM   #12
LeeS17
Almost final result. I got a -75mm at the front and -45 at the back. I still need to balance it but for now it will do it. I would have love to lower the back more and raise the front but the back is already as low as it will get.
Thanks for the help.
~Lee
Old 04-14-2016, 08:12 PM   #13
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
The back is as low as it'll go? I thought coilovers let you put the car on the ground?
Old 04-14-2016, 09:16 PM   #14
LeeS17
My rear spring are quite stiff. They are at the lowest setting and I match the damper too my best. I could get it lower but I will lost damping to one point I lost all damping. Thay was my issue few post ago.
Also, these coil look to be preformance oriented and not for the look. Maybe after few miles they will settle lower but I want to get my alignment before I start rolling with it.
~Lee
Old 04-15-2016, 10:09 AM   #15
ern-diz
ern-diz's Avatar
~Lee
Gotcha. Post a few more pics when you can, would enjoy seeing them. Just resize them a bit so we can take it all in at once lol.
Old 04-16-2016, 01:24 PM   #16
LeeS17
Here more picture and I find out how to resize picture in batch :D
Some cleaning are needed and the caliper may need and other paint job.
Old 04-16-2016, 01:28 PM   #17
The back looks like it has only dropped very little from stock height.
Old 04-16-2016, 02:20 PM   #18
LeeS17
It actually is 45mm lower than stock. From the wheel arch to the ring on the tire, it was 124mm all around the car. It is now 80mm in the back et 55 in the front. That is why the back look high up. I may try something tomorrow because the weather outside will be really nice, sunny with a temperature around 18C/65F, which is better than the snowy 0C/32F when I install the coilovers last weekend
coilovers, hsd, monopro
***2002 ECHO,Rear Apexi Coilovers to be modified to fit, Energy Sus bushings *** Hussain-Vtec Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-27-2012 06:55 PM
FS Finally my MB weapons with tires and Tein Coilovers! jekqmb Items for Sale by private party 37 12-05-2011 11:03 PM
Toyota Yaris HSD Concept - Preview of the upcoming Yaris Hybrid (teaser pic) Kal-El Third Gen Yaris General Discussion 37 06-25-2011 06:16 AM
D2 Racing Coilovers Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-23-2011 05:01 AM
FS: BC Racing Coilovers BR Series Non-Inverted FunctionSpec Items for Sale by private party 9 06-02-2010 01:34 PM
