Old 05-08-2016, 03:22 PM   #1
Midwesterner
Drives: 2009 Yaris Hatchback
Radiator
I hit a raccoon early this morning on the highway. I didn't stop, but shortly after, started getting temp. light and check engine light. Took it easy because I was so close to home. Daylight came and I checked it out... enormous hole in the radiator.
The question is... can I limp a few more miles to a repair shop, staying at 25 mph or less? Or should I have it towed? I know it is a risk... what would you do?
It's a 2009, and the hole was punched by the engine... there is a piece that sticks forward from the engine, which hit when the radiator got pushed back.
Sent from my SM-N900R4 using Tapatalk
Midwesterner is offline   Reply With Quote
Radiator Fan not working.. Beubeu DIY / Maintenance / Service 3 09-21-2015 12:53 PM
won't start after broken radiator wolverine565 DIY / Maintenance / Service 4 10-17-2013 09:47 AM
radiator small leak esse10 DIY / Maintenance / Service 2 08-20-2013 11:40 AM
Radiator Change TMR3 DIY / Maintenance / Service 5 06-22-2012 12:11 PM
Anyone put in a performance radiator? mrbond Performance Modifications 19 03-18-2009 10:32 PM
