Old 06-05-2016, 10:05 PM   #1
froger
Drives: 08 yaris 1.8 dual vvti 5sp
SCION XB BRAKE UPGRADE
The other day a free set of 2012 Xb front calipers came into my hands,my friend who had a Scion Xd always wanted a cheap front brake upgrade and so I was wondering if it would work.Turns out scion xb,Scion xd ,corolla,rav4 ,matrix and yaris all have all the same bolt pattern for the calipers ,so any one of the vehicles are interchangeable but the problem was the rotor because the center bore of the rotors are different.So after hours of research I found that the scion xb rotor will not work because it has a center hub size of 62 mm but a 1992 celica gts rotor had possibilities because it has similar dimensions to the scion xb rotor,just 1.8 mm bigger diameter and center hub diameter was 54.04 mm and the wheel bolt pattern was 5 x 100 . This center bore was so close to the xd (55mm) but smaller by a bout 1 mm. So i decided to experiment , bought a set of 92 Celica rotors and decided to carefully shave the 1mm off the center bore.Fits on the car no issues no rubbing ,brakes stops really well however i will probably buy another set and get them professionally machined.
SCION XD ROTOR
THICKNESS 22MM
DIAMETER 275MM
CALIPER PISTON DIAMETER
60MM
SCION XB ROTOR
THICKNESS 25MM
DIAMETER 275MM
63MM
92 CELICA GTS ROTOR
THICKNESS 25MM
DIAMETER 276.8MM
ALSO LOOKING FOR AWAY TO FIT V6 RAV4 BRAKES,THEIR IS A ROTOR IN EUROPE THAT MAY WORK.I WILL TRY AND FIND OUT IF IT WORKS,ON PAPER EVERYTHING LOOKS GOOD BUT COST OF ROTORS ARE VERY EXPENSIVE.
froger is offline   Reply With Quote
The front brake upgrade thread - just the facts brushforhire DIY / Maintenance / Service 35 04-07-2022 07:07 AM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 08:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 07:34 PM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
