Old 06-12-2016, 08:52 PM   #1
fourbangingfun
fourbangingfun's Avatar
Red face Front Disc Brake Slide Pins - Question
Hey everyone.
So today I pulled apart the front brakes on my 07 sedan. It has 170k miles, and the rotors/pads were replace at 100k miles. The bottom slide pin was frozen in place on the right front wheel. I was able to pull it out, clean it on a wheel brush, lube with anti-seize and reinstall.
My question is this: that lower pin had a rubber ring around it towards the end of the pin. It was all chewed up and destroyed. I ended up just pulling it off (along with the one on the opposite side) and installing the pin without the rubber ring.
Will this cause any problems? I don't really see what the purpose of that rubber ring is, as the hole for the slide pin has a dead end at the bottom of it.
Thanks
fourbangingfun is offline   Reply With Quote
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 05:32 AM
ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS kargoboy YarisUniverse 11 01-20-2009 04:43 PM
Front Bumper Question tca4 Cosmetic Modifications (Exterior/Interior) 8 01-30-2007 03:58 PM
Stupid Front bumper question (sedan) amishpriest General Yaris / Vitz Discussion 17 07-26-2006 03:10 AM
