Old 06-29-2016, 07:05 AM   #1
mik23
Drives: yaris 2005
YARIS Clutch Cable
All,
Can anyone advise how to replace the clutch cable or how can I lube it.
I am feeling the clutch pedal is hard to press sometime.
Clutch it self is working fine.
thanks\
mik23 is offline   Reply With Quote
Old 06-29-2016, 09:07 AM   #2
Good luck with that one, the clutch is hydraulic.
Old 06-29-2016, 09:40 AM   #3
mik23
Drives: yaris 2005
Cheers for that
Old 06-29-2016, 10:00 AM   #4
Get someone to help you bleed the system. There might be some moisture in the line
Old 06-29-2016, 10:01 AM   #5
mik23
Drives: yaris 2005
Do i need to bleed it and then refill ?
Old 06-29-2016, 10:02 AM   #6
It shares the system with the brakes. So just keep an eye on the level and make sure you don't let it go dry.
Old 06-29-2016, 10:11 AM   #7
mik23
Drives: yaris 2005
Old 06-29-2016, 10:11 AM   #8
mik23
Drives: yaris 2005
Is it this one to bleed
Old 06-29-2016, 10:28 AM   #9
bronsin
bronsin's Avatar
Yes. We motorcycle riders bleed our brakes and clutch once a year and change the fluid every two years.
Its cheap and easy, ensures proper operation, prevents untimely problems, keeps the bleeder bolts from seizing and snapping off when eventually you have to loosen them to bleed/change the fluid, and makes things last longer.
Old 07-01-2016, 07:30 AM   #10
mik23
Drives: yaris 2005
Old 07-01-2016, 07:31 AM   #11
mik23
Drives: yaris 2005
Old 07-01-2016, 07:32 AM   #12
mik23
Drives: yaris 2005
Is this the reservoir i need to refill. I havent done this before so any advise would be highly appreciated
Cheers
Old 07-01-2016, 07:49 AM   #13
mik23
Drives: yaris 2005
which oil for refill
Old 07-01-2016, 08:17 AM   #14
DOT3 or DOT4 Brake fluid only. It says right on the cap and in your owner's manual.
Old 07-01-2016, 10:28 AM   #15
mik23
Drives: yaris 2005
Cheers gents got it it is dot 4
Old 07-03-2016, 08:26 AM   #16
mik23
Drives: yaris 2005
Thanks Gents it is much better now
Old 07-03-2016, 08:55 AM   #17
Did any nasty dark fluid come out
Old 07-03-2016, 09:11 AM   #18
mik23
Drives: yaris 2005
Yeh thats strange bcz the one in container is clean not sure how all that gets in.
How to tighten handbrake cable? (Yaris Sedan) NadPhone DIY / Maintenance / Service 5 01-04-2018 10:55 AM
Aftermarket Clutch Q's tmontague Performance Modifications 5 03-05-2016 04:33 PM
'54 T2 Yaris 1.0 VVTi automatic clutch / gearbox / starting problem Lettuce UK 0 09-30-2010 06:21 AM
Is it me or does the Yaris have a touchy clutch? tomato General Yaris / Vitz Discussion 17 02-23-2009 08:33 PM
