Old 07-10-2016, 10:46 PM   #1
laurenth
laurenth's Avatar
Drives: yaris
windshield washer pump troubles
Hi,
I have an 04 1.0 and the front windshield washer pump was getting weaker and weaker on me then totally quit so I decided to replace it.
So I plug the new one and it doesn't work... after switching the wiring with the rear one it runs fine: it's apparent that it isn't getting electric current.
The fuses under the hood are all ok, where should I look? do switches at the steering go bad?
Edit: clarification.
laurenth is offline   Reply With Quote
Old 07-10-2016, 11:04 PM   #2
alanwagen
maybe clogged
Originally Posted by laurenth View Post
Hi,
So I plug the new one and it doesn't work... after switching the wiring with the rear one it runs fine: it's apparent that it isn't getting any juice.
If at anytime you ran just water, you could have algae or some other junk. Check to be sure the tank is clean and nothing in clogging the intake and then go from there.
Old 07-11-2016, 03:42 AM   #3
laurenth
laurenth's Avatar
Drives: yaris
Poor wording of mine: by any juice I meant electric current.
Old 07-11-2016, 08:56 AM   #4
Did you try plugging the hose for the front sprayers to the rear pump? Make sure the lines or the nozzles aren't plugged up.
Next step would be to take a Voltage reading.
Check the plug to make sure there is no corrosion in the connector. I've never heard of a switch going bad, but it is possible for a mechanical switch to fail.
Old 07-12-2016, 06:38 AM   #5
laurenth
laurenth's Avatar
Drives: yaris
" Did you try plugging the hose for the front sprayers to the rear pump?"
Yep, no clogging, I switched to my rear pump for now since it isn't as crucial as the front.
there should be a relay somewhere to take some voltage reading but where, I don't know.
Old 07-12-2016, 08:11 AM   #6
I don't think theres a relay.
Removing Windshield Washer AGlobalThreat Fuel Economy Forum 14 05-02-2011 07:27 PM
Windshield washer fluid Twistoffate0817 General Yaris / Vitz Discussion 5 05-12-2010 12:47 PM
Windshield Washer indicater always on mlaverdiere General Yaris / Vitz Discussion 3 01-17-2010 02:43 PM
Windshield Washer Indicator captainm27 General Yaris / Vitz Discussion 25 01-21-2009 07:26 PM
New TSB Bulletin For Windshield Washer Sprayer Yaris General Yaris / Vitz Discussion 14 06-01-2007 01:47 PM
