Old 07-15-2016, 04:01 PM   #1
Canasta
Drives: 2013 Yaris 1.3
Clutch slave cylinder location question
Hi
Im planning to bleed the clutch slave cylinder.
It's for two reasons, just as routine maintenance and also as the clutch is quite hard at the moment and i'd like to try this to see if it can make any difference.
Its the 1NR-FE engine I have, I can see a bleed valve at a junction where the hydraulic line splits, with one line going towards the left front wheel brake and the other line dissapears into the engine compartment. (The car is the right hand drive version if that makes any difference)
But I cant seem to locate the slave cylinder and it's bleed valve. Has anyone got a photo or diagram that shows where to find it?
Thanks
Canasta is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
'07 Yaris Clutch replacement dinop DIY / Maintenance / Service 12 04-22-2013 04:47 AM
Clutch question. Black_griffin6 Performance Modifications 6 04-04-2013 04:30 PM
Selling my Yaris - Clutch Replacement Question Swoleslaw DIY / Maintenance / Service 9 11-05-2011 11:27 AM
Question: Screws location of Rear Light joeblack DIY / Maintenance / Service 2 12-21-2009 09:28 PM
