Old 08-06-2016, 01:45 PM   #1
SirJanin
Drives: 2007 Yaris
Strange light issue
Hello, we are having a strange issue with our 2007 Yaris hatchback. If we switch on the dash board lights (when driving at night) both tail lights go out. Turn the dash lights off and the come back on. So now when driving at night (which we avoid) we have no dash lights what so ever. I checked all the fuses and they seem fine (not sure if its a fuse issues due to the fact that they work, just not together). Has anyone heard of this happening or have any idea what may be going on? Thanks
SirJanin is offline   Reply With Quote
Old 08-06-2016, 02:08 PM   #2
That's a new one.
Old 08-06-2016, 04:13 PM   #3
I have not heard of that specifically, but have heard of other similar strange issues cause by an improperly seated headlight stalk connector or a bad headlight stalk.
Start by dropping the lower steering column cover (two screws accessed by rotating the steering wheel to either side and one by the tilt lever). Try reseating the connector and see if that works. If not, try wiggling the connector's wires with it connected.
Old 08-06-2016, 04:48 PM   #4
SirJanin
Drives: 2007 Yaris
Thank you, i will give this a shot, thanks.
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
Tail light issue pat005 DIY / Maintenance / Service 3 04-11-2017 04:10 AM
Yaris XP rear fog light issue bubu DIY / Maintenance / Service 4 12-05-2013 03:03 PM
Side Marker Light Issue. HELP! ApolloJA DIY / Maintenance / Service 6 07-22-2013 10:52 PM
Parking Light issue justin27zamora DIY / Maintenance / Service 0 06-16-2013 01:58 AM
