Old 09-18-2016, 06:48 AM   #1
TnF
Drives: Yaris XP90
1ND-TV 1.4L D4D XP90 starting problems
Hello guys. I own a Yaris XP90 diesel that for the past week has started having problems starting up. No engine code (although i haven't yet connected to the obd to check in Techstream), did full service, oil, oil filter, air filter, fuel filter (of course it was primed), coolant and no change. When it starts it behaves normal, same power no issues at all. Only when starting and it seems if i take a long drive then stop it becomes extremely difficult to start. Today it took 5 long cranks to get it to start! I also checked the SCV (?) valve on the fuel pump while i did the service, cleaned it up, checked resistance and used 12v to check if it is working and seemed fine. Of course battery is perfectly fine, cranks like hell (no slow down whatever). Also we used STP diesel injector cleaner but like i said no change at all from the service.
Also i've used Techsteam yesterday, no DTC codes, Rail pressure is 30Mpa at idle (850rpm), 14Mpa at cranking (260rpm). Is this enough? Anyone has a pdf fsm i can download??
(btw all other paremeters looked ok)
Any ideas what can it be?
Kind regards!
TnF is offline   Reply With Quote
Boost pressure values on Yaris 1.4L D4D 90 rasyaya Forced Induction Forum 10 01-16-2022 01:21 PM
Starting problems after fuel filter replacement?? Berni271 DIY / Maintenance / Service 2 04-23-2014 06:46 AM
New D4D My10 With Problems... cyberguy DIY / Maintenance / Service 3 11-17-2010 07:53 AM
problems starting my yaris yaristeacher DIY / Maintenance / Service 13 07-07-2010 10:57 PM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
