Old 09-29-2016, 12:13 AM   #1
JudgeM
JudgeM's Avatar
Drives: 2005 Toyota Vitz RS
Unhappy Headlights not working on my Caldina, help pls!
Hi all.
I bought a 1993 Toyota Caldina 2.0 (4wd petrol) a couple of months ago as a kind of a project car to learn some automotive repair/maintenance on. She's a really tired car now and has few small issues here and there
So far the biggest issue is the headlamps have decided to stop working.
Both low and high beam do not work. I think it is intermittent, because once while driving they decided to turn on for a short moment.
I have checked and tested the relay that's under the bonnet labelled 'head' and it is fine.
What should I check next ? parking lights are fine btw.
JudgeM is offline   Reply With Quote
Old 09-29-2016, 12:18 AM   #2
You've checked for power at the bulbs?
Also, not sure on the wiring schematic of that car, so make sure there isn't a common ground point that's corroded or loose.
Old 09-30-2016, 10:40 PM   #3
JudgeM
JudgeM's Avatar
Arrow
Power at bulbs all fine. I did a bit of more digging around, its a bit hard without a wiring diagram, I used 96 corolla diagram that's similar.
I think I've narrowed down the problem:
-Relay is good
-Dimmer switch is good
->Wiring between relay and Dimmer switch seems to be the problem. I grounded the point at the relay which is what the dimmer switch does and it lights up. I suspect loose connection in the engine room fuse box where the relay is located. I gotta go borrow some tools so I can open it up.
Does anyone have a wiring diagram for this car ? or something more similar like a Corona Wagon ?
Old 10-09-2016, 08:46 PM   #4
JudgeM
JudgeM's Avatar
Fixed it
Upon further inspection, the relay coil was not getting its ground signal from the switch. So somewhere between the dimmer switch and relay coil there is an open circuit.
aint nobody got time to open up the hole car and trace the wiring so I just added my own wiring from the dimmer switch to the relay. Headlights working fine now
caldina, headlights
headlights not working.... Judas Iscariot DIY / Maintenance / Service 66 09-05-2019 11:27 PM
Headlights On reminder not working?? jeeper5usa DIY / Maintenance / Service 0 03-20-2016 01:27 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Headlights not working !! HELP dav DIY / Maintenance / Service 1 09-26-2013 06:43 AM
Headlights stopped working - need help Split Cosmetic Modifications (Exterior/Interior) 2 03-02-2012 11:04 AM
