Old 10-03-2016, 07:32 PM   #1
ironarmscott
Installed 215/35r18 on 2012 4 door hatch. Spring question
2012 4 door hatch with 215/35r18 how low can I go looking for only 1 1/2" drop which springs to use and where to order from I am in Canada but travel to USA couple times a month
ironarmscott is offline   Reply With Quote
Old 10-03-2016, 08:25 PM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
What are your wheel specs?
Old 10-03-2016, 10:11 PM   #3
ironarmscott
as per offset I will have to measure
Old 10-08-2016, 05:04 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
With that tire size on TRD wheels I experienced slight inside contact (rubbed off the paint) on the inner wheel well at full lock. Also rubbed the outer fender lip (and wore through the plastic fender liner) when the suspension compressed. This with TRD springs and dampers. No rear issues. Due to the added nose weight due to the Blitz S/C my front drop was about 2 inches. I also had the front camber set at 1 1/2 degrees negative past OEM spec. It was tolerable and no tire damage was experienced. My biggest issue was ride quality on 35's over our frost heaved Ontario roadways.
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Spring question? jekqmb Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-19-2009 06:54 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 12:33 PM
